โDec-17-2020 04:40 AM
โDec-17-2020 09:50 AM
โDec-17-2020 09:08 AM
way2roll wrote:
Truth be told, a lot of the MTB set sling their bikes over a tailgate - no rack needed.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โDec-17-2020 08:19 AM
ajriding wrote:
no, lol. You are at the completely wrong forum. Check the cycling forums. pinkbike dot com or many others Im sure...
If you want a truly great bike rack then look at your local bicycle shops. The people who ride bikes all the time will know what a good rack is versus the crappy one you found on an RV search.
Huge quality difference and huge performance difference from a walmark/rv store rack to a bike shop quality one.
โDec-17-2020 07:39 AM
โDec-17-2020 07:20 AM
โDec-17-2020 07:19 AM
Slack in the receiver is what causes most problems. Best solution I have found to this is to drill a hole in the bottom of the receiver and weld a large nut over it. Then thread a bolt through it that you can tighten against the racks draw bar when installed. The bigger the nut and bolt the better. Takes all the slop out of the hitch and makes for a solid rackOur Yakima hitch comes with this built in and it makes a big difference. We have the swing away model because we need to easily get to our rear doors, probably not needed for a class C.
โDec-17-2020 06:37 AM
โDec-17-2020 06:29 AM
โDec-17-2020 06:24 AM
โDec-17-2020 05:42 AM
โDec-17-2020 05:40 AM
โDec-17-2020 05:01 AM
โDec-17-2020 04:48 AM
