Beginning the second season with a Reese Stait Line 12K and still donโt feel like itโs adjusted properly. Dealer installed and setup on my 2005 Chevy 2500HD 6.0 gas that has the towing package. TT is a little under 9K dry with a 1100 lb tongue weight.
Started with 4 links hanging last year and had more sway then I liked and loved it to 5 links hanging and it improved but still felt less steering control then I felt comfortable with but finished the season with that setting,
This year I thought what the heck go up another link to 6 links hanging and itโs in the 7th. Well this made a tremendous difference in handling and steering but it had a lot of tension on the bars but still manageable to set with the cheater bar. Only problem is the noise. I know itโs been said many times if itโs not making noise itโs not working. I agree but this has a huge clunk when making any turn over 15 degrees at low speed. I assume itโs the design of tge Strait Line that has the bracket to keep the bars straight when towing straight and the bar pops back into the bracket. I have to admit that Iโve not lubricants the hitch this year according to the manufacturers recommendations which I did last year. Could the problem be that simple ?
Iโm worried the bars have too much tension. Is that possible?
Could the entire hitch need readjustment since Iโm up 2 links from original settings? Dealer tech told me to adjust with the chains as needed and more links hanging makes it feel much better, just that noise worried me.
I switched from a smaller Equalizer brand hitch to this when we upgraded TT. Sometimes I wish Iโd just gotten another Equalizer.
Anyone with Reese Stait Line experience that can give me some insight.
TIA
Mike
Mike and Donna
2016 Chevy 2500HD
2020 Open Range Light 312BH
