Removing decal residue from fiberglass
Herd_Fan
I removed a couple decals, leaving some residue behind. What products have you guys found to be best/safest for removal? I have some Goof Off, but have never used it on the trailer before. Thanks!
2017 Flagstaff Micro Lite 21 DS
2007 Dodge 2500 5.9L CTD, 4x4, quad cab
18 REPLIES 18
ppine
Acetone is the standard for working around fiberglass. I used to build fiberglass sail boats.
Grit_dog
Navigator
Navigator
wilber1 wrote:
If you have some kicking around, try some Lysol toilet cleaner. You can mix it with hydrogen peroxide if you want to thin it. Don't know if it will work on decal marks but it works great for getting stains of my boat's gelcoat.
Uhhh no. Muratic acid (HCl) is good at dissolving mineral deposits and and organics. It's not a solvent for rubber/glue products. However it will do a great job at rusting any bare steel it touches or oxidizing aluminum severely and as a bonus it will etch your concrete driveway.
Adam_H
LOL, I use camp fuel or Kerosene. Won't hurt paint and we all probably have some. Use it for bug and tar removal on paint too.
Adam
2007 Fleetwood Avalon HW PUP
2001 Excursion 6.8L V10 3.73
2005 F150 5.4L
Gone but not Forgotten: 1971 Trailstar PUP, 2002 Fleetwood Wilderness Northwest Edition, 2002 Keystone Bobcat 280-EB
wilber1
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
minnow
This is what I used to remove decals and the glue residue. Worked absolutely fantastic:
GraphXoff
Lwiddis
Since I have had WD40 on hand at all times since age 17, thatโ€™s my choice...but not for bicycle lubrication. .
mike-s
The first two mentioned (Goo-Gone and WD40 {basically Stoddard solvent and mineral oil})are good choices. I'll add any of the citrus oil ones, like PB Blaster.
Ivylog
Citrus air freshener...works the best of anything Iโ€™ve tried.
Upgraded with a 08 HR Navigator 45โ€™...
phemens
Just did mine a few weeks ago with Goo Gone, worked fine, no issues. All the dealer decals gone, looks much cleaner!
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
jfkmk
Ives used Turtle Wax bumper sticker remover, but truthfully Iโ€™m with Dutchmen....WD40 works great!
BB_TX
3M adhesive remover when I removed some of my decals worked great. Basically melts the adhesive.
sgip2000
I use Unbelievable! Un-Goo, but it is hard to find at times. Works on anything sticky.
Bionic_Man
This from 3M.
It was recommended to get the clear bra off my car. I have used it for that, as well as removing adhesive from permits that are on my windshield, as well as on my fiberglass boat and aluminum fishing boat.
Works way better than anything else I have tried (including goo gone and WD40.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Dave5143
I've been reading good reviews for Rapid Remover for Vinyl Decals.
Dave & Mary
2012 Denali 289RK
Ford F250 Lariat Powerstroke 6.7L Diesel
