โSep-29-2014 09:02 AM
โOct-01-2014 10:32 AM
ScottG wrote:All adhesives are weaker in peel than in tension. If the adhesive is epoxy, solvent won't work if it is some kind of contact adhesive acetone would be the best bet to soften the adhesive. I would try to start the peel with a razor after acetone at the bond line then grab with Visegrips to peel it off.
When removing them, pull it straight back against the itself. If you pull it off perpendicular to the surface you have the highest risk of damage.
โSep-30-2014 08:01 PM
โSep-30-2014 10:11 AM
โSep-29-2014 12:29 PM
PeteK-Hou wrote:TurnStyle wrote:
If you can get under an edge you might try using a piece of dental floss to separate the Velcro from the surface then use goof off to remove the adhesive.
Monofiliment fishing line works a bit better and won't break as easy.
โSep-29-2014 11:42 AM
โSep-29-2014 11:32 AM
โSep-29-2014 09:34 AM
โSep-29-2014 09:18 AM
โSep-29-2014 09:13 AM
โSep-29-2014 09:11 AM
โSep-29-2014 09:07 AM
