Risk of Putting Slightly More Weight Back To Front Axle
four22
Dialing in my equalizer 4 point and have a simple question... my truck with no trailer front axle weight is 3500 pounds on a scale with a full tank and loaded ready to go...
I ran across the scales on our last trip and the steer axle was 3405 Pounds with the trailer and truck loaded ready to go. I'm not over any ratings but I am close to them (250 pounds below the closest axle rating)...
I added 1 more washer to my hitch to try to gain a little more steering control and am curious if there are any reservations to putting slightly more weight back to the front with the WDH.... meaning like 3550 vs the no trailer 3500...
The extra washer made a dramatic difference going from storage to our home but I wanted a sanity check to make sure I wasn't creating an unsafe condition.
Thanks for the help
15 REPLIES 15
four22
Drive report:
80 miles to where we're staying as I type. The extra washer made it a 65mph, 1 handed driving experience. Set the cruise and just drove nice and easy. Now when we hit the storm 60 miles in I could feel the wind but never was scary honestly.
Laying in bed as I listen to the rain fall is one of the most relaxing times in the world!
Hannibal
What is the rear axle weight rating on your F150? 4300 lbs seems a bit high off the top of my grape. Do you really have 1500~ lbs of tongue weight even with WD? Considering that, I'd say you definitely did the right thing. If it tows better, you can't argue with success.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
PDX_Zs
Huntindog wrote:
PDX.Zs wrote:
No horse in this race, but I am impressed that you can measure with this level of resolution a system with relatively coarse adjustment.
My only commentary is that I must be overly simplifying this because I just do the old add weight distribution until the front return to almosts unloaded ride height thing and go thing.
The adjustment can be as coarse or fine as you want.
Washers can be had in different thicknesses. I have mixed and matched some to get it exactly how I want it.
Either way, I am impressed.
๐Ÿ™‚
Huntindog
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
K3WE
No you're just not obsessing about a negligible amount of weight transfer.
You're doing it right and the OP will be fine either way too.....
Apologies- I take slight issue with 'fine either way' . And it should be about HANDLING as much as the exact weight, or appearance...and maybe... ideally ADDING some proportional weight to the front more than aiming for neutral.
/nit picking.
Grit_dog
Navigator
Navigator
four22
Thanks for the help. I wanted to make sure I wasn't creating an unsafe condition. We'll see in about 5 hours how well it does out on the highway!!
Happy camping and thanks to those that served our country.
eHoefler
You never want to have any weight removed from the steer axle when towing anything, adding weight to the steer is ideal. That is why they invented the equlizing hitch, to transfer weight to the steer. You have found out the reason for doing this. Better control and stabiity.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
four22
I'll need to verify at a scale after adding a washer but my weights from the last trip were:
No trailer:
Steer axle 3450
Drive axle: 2850
With trailer last trip:
Steer axle: 3405
Drive axle: 4300
This is all hypothetical but.... If I were to take 150 pounds off the rear axle, put 100 up front and 50 back to the trailer my numbers would be:
Hypothetical:
Steer axle: 3500
Drive axle: 4150
Still heavier loaded on the back and closer to a 50/50.
The main reason for me asking was to make sure I wasnt doing something stupid and would cause an unsafe condition (aka jack knifing or something of that nature) but it sounds like I'm no where near that dramatic of a set up yet.
PDX_Zs
tll
On my setup I have increased the weight on my front axle by about 75 lbs more than unloaded. This gives me the best towing performance. I think the key here is if you do this is to not unload the rear axle, and have the rear axle still loaded by at least (if not more) the same amount as the front. In my case I have about 200 lbs on the rear, 75 on the front.
2015 Starcraft 299BHU
2011 Jayco X23J(sold)
2009 Ford F150 FX4 SuperCrew
Turtle_n_Peeps
OP, I would never do this and here is why:
Trucks are notoriously unbalanced. That is why you see people putting sand bags or heavy plates in their beds. It's to get a better weight bias. The closer you get to 50/50 the better a vehicle will handle the better is will brake............the better it will do everything.
The new trucks are better. That's why you see the engines of new trucks stuffed up under the dash. OEM is trying to get close to a 50/50 weight bias.
Also; when you panic brake all the energy (weight) will try to go to the front bumper of the TV. When this happens it will squash the front suspension of the TV. The back of the TV will unload and try to lift the tongue of the trailer. The higher the front of the trailer and tongue the more successful it will be. This is a bad thing. Your trailer will then try to jack knife. For the best handling TV and braking combo you need to have your trailer an inch or two lower in the front and have a 50/50 weight bias on your TV when loaded.
The goal is when under panic braking is to get the hitch to line up with the tongue of the trailer. Not lift the back of the TV or squash it. With this you will get the best handling and braking TV/trailer combo.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
qtla9111
In this Equalizer video they talk about starting with 5 washers and later adding additional ones.
Adding Washers
2005 Dodge Durango Hemi
2008 Funfinder 230DS
Living and Boondocking Mexico Blog
CaLBaR
I wouldn't worry about it. Better to have 50 - 100 lbs more than less as your experience in handling shows.
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
