Rolling up Awning SHADE in Awning...
theunclebeef
I was wondering if any of you have ever rolled the awing "shade" up when you retract your awning? Seem like a great idea!?!?!
Brian, Lisa, Zack and Carly and Ruby
99' Ford 350 crew long bed diesel Edge controller, Over size Trans cooler, Air Bags.
18' Montana High Country 310re
9 REPLIES 9
LOFAT36
Timeking wrote:
I too am looking at the Vista Shade for my electric/automatic awning but have a few questions/concerns:
1. Is the zipper something that is going to rust/discolor the underbelly of the awning?
2. Are you saying you a) have an automatic awning and roll the whole 8 ft up with the awning when desired? or b) you have to take off the bottom 6 ft panel and THEN roll it up?
. Top part stays on, not the bottom. The zipper is plastic not metal.
Timeking
JW_of_Opechee_S
We have " VISTA Shade" The top 2' section stays in the track and unzip the bottom section in less than 5 seconds in the wind to roll up the awning. We leave it in all the time, even when travelling because it doesn't effect how the awning stores for travel. You order the size you want so that you can have different bottoms if needed.
Have Fiver will travel with little or no notice at all. I do need to stop at rest areas now and then:)
RVman3252
pennysmom09 wrote:
Yes, we roll up our shade with the awning, but only for wind. When we travel, we remove it.
We do the same.
RVman3252
3252Px3 KZ Sportsmen Limited Triple Slide Fifth Wheel
Dodge Ram HD3500 CrewCab, Longbed 4x4 Cummins w/ PullRite Super 5th
Good Sam Life Member
mgirardo
We hang lights from our awning with the little hangers that slide into the awning tube and have little S hooks that hang from the hangers. I forgot to remove one of the S hooks and rolled up the awning. The awning did not roll up properly and as Thom02099 mentioned, it did put the lever at an awkward location.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
Thom02099
For an automatic awning, perhaps not an issue. For a manual awning, the added thickness changes the location/angle of the little lever that you must change to make it go up or down. Could put it in a very inconvenient location. I tried it with mine and it was more difficult to let the awning back out due to the angle change for that lever.
2007 GMC Sierra SLE 3500HD Dually
2016 Coachmen Catalina Legacy Edition 243RBS
2007 Keystone Outback 25RSS - R.I.P.
1492
Moderator
Moderator
Moved from Forum Posting Help and Support
pennysmom09
Nancy and Doug
2015 KZ Durango 325RL FW
Jim
What's the users guide for the shade say?
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
