โJul-08-2015 09:51 AM
โJul-10-2015 02:51 PM
โJul-10-2015 11:31 AM
โJul-09-2015 06:31 PM
โJul-08-2015 06:12 PM
โJul-08-2015 06:01 PM
โJul-08-2015 04:33 PM
wbwood wrote:
You mentioned that you were not level when camping and just figured 6 gallons of error because of that. It can also cause your tank sensors to not read correctly.
โJul-08-2015 01:59 PM
โJul-08-2015 12:40 PM
โJul-08-2015 11:12 AM
โJul-08-2015 10:43 AM
โJul-08-2015 10:24 AM
texasAUtiger wrote:Are you sure the tank is emptying completely when you drain it? Could there be something preventing it from draining all the way?DutchmenSport wrote:
Is it possible your gray and black tank are 2 different sizes?
Do the same experiment again, only this time, keep filling the gray until water back-up in your drain. Then you'll know REALLY how much is truly holds.
Black tank... I never use the sensors. Just look down the toilet hole! Works ok for me.
Sorry, I left that part out: at 26 gallons the gray water began to back up into the tub (you could hear it before it started).
I will run the same experiment on the black tanks and report back.
I am pulling the specs for the gray and black tank sizes off the manufacturer website but my experiments will tell if these are accurate.
In case it matters, the trailer is slightly off level back-to-front with the rear of the trailer lower by 1-2". It was pretty level at the campsite though.
โJul-08-2015 10:08 AM
โJul-08-2015 09:59 AM
โJul-08-2015 09:55 AM
