May-08-2013 09:15 AM
Brian/Lynette
and the 3 Cubs,2009 Cherokee Wolf Pack 30WP
May-12-2013 12:22 PM
May-08-2013 06:58 PM
So if it raises the front 4 inches you have to have a real low hitch or
May-08-2013 06:49 PM
Vulcaneer wrote:chipster wrote:
I did like the Super Glide but I understand you have to be more in a straight line to hook up andI would have to purchase a Airborne kingpin also to help with the chucking.
No...You would not need to buy a Airborne Kingpin to help with the chucking. My 7 year old Superglide holds the kingpin so well it does not allow any chucking. If you do decide to buy the SuperGlide, I recommend you do NOT buy the Airborne pinbox, until you pull a few times. Then see if you still need to buy the Airborne pinbox. Most likely you'll not need it.
Brian/Lynette
May-08-2013 06:48 PM
May-08-2013 06:27 PM
Brian/Lynette
May-08-2013 04:58 PM
I have been considering the Airborne for some time, and spent several hours the other day searching and looking at videos. I never thought of the effect it would have on towing stability.
May-08-2013 04:02 PM
May-08-2013 03:39 PM
wittmeba wrote:
One reason is $$$. Seems like a waste.
Im not one in favor of the Sidewinder pinbox due to the 22" extension from the kingpin point in the hitch to the turret where the 5th pivots.
Additionally you have to block the Superglide from sliding.
May-08-2013 03:35 PM
May-08-2013 03:03 PM
wittmeba wrote:
I dont think the Superglide requires a straight line hookup but the TV must be within about 15º to the 5th wheel.
Most of the better hitches have the side/side pivot and are vertically adjustable.
Im sure I would not mix a Superglide with a Sidewinder.
Hitch links:
http://gotnarcosis.com/brucewittmeier/technical/FifthWheelHitchComments.html
Brian/Lynette
May-08-2013 02:37 PM
May-08-2013 11:53 AM
May-08-2013 11:42 AM
Brian/Lynette
May-08-2013 11:38 AM
hammer21661 wrote:
I think you can lock a super glide if that makes a difference.....
