โMar-19-2015 07:19 AM
โMar-21-2015 09:04 AM
โMar-20-2015 01:27 PM
โMar-19-2015 08:30 PM
โMar-19-2015 10:56 AM
leeper wrote:
Check alignment for gaps in the gaskets. If the slide is in, check outside seals and gaskets. When it is out, check inside gaskets meaning top of slide. Should be NO gaps. Are the distance the same on each end. Some times the slides need adjustments at a service shop.
โMar-19-2015 10:44 AM
โMar-19-2015 10:23 AM
โMar-19-2015 09:49 AM
jamnw wrote:If you just typed that exact phrase in the little search box, that's exactly what it searches for. It's not google.
I searched that, but got no results.
โMar-19-2015 09:48 AM
MTPockets1 wrote:
The Lippert slide manual (downloaded from website) for hydraulic slides, says to actuate slide every seven days, or if left out to use silicone spray lube on the hydraulic Rams and slide seals. Also, change reservoir fluid annually after first two years. The only mention on electric slide is to adjust cable if it becomes loose.
โMar-19-2015 09:40 AM
โMar-19-2015 09:19 AM
โMar-19-2015 08:45 AM
โMar-19-2015 08:26 AM
Fizz wrote:
I had only one problem with mine.
There is a folding metal bar that supports all the wiring. It fold in and out with the room. It rusted up and the hinge broke. An easy fix for me, now I'll keep an eye on it and oil it when needed.
โMar-19-2015 08:10 AM
