roof cleaner
boingram
...need to clean the roof on our tt...2 yrs old. ..used tilex on the awning and it was great...how bout mixin some up and mopping on roof...very cautious of the sidewalls. ..thx...bo
32 REPLIES 32
jnharley
To me, the main reason to wash and wax an RV top to bottom aside from aesthetics is to check for things that need attention like worn caulk, cracked window seals, etc. It is much easier to check for these things on a clean RV.
2015 Dodge Dually
2012 NuWa Discover America 355CK
mikhen
ddndoug wrote:
I was watching a video that showed a guy cleaning an RV robber roof with a pressure washer, anyone using one on there roofs?
If you guys are getting on your roofs to clean them, how are you inspecting them for tears and/or water leaks?
Doug
I use a pressure washer for quick cleaning. Mine has a delicate (low) setting and I keep it a distance away.
Veebyes
Doug
Good question. How much pressure does a pressure washer put on a surface?
Try cleaning a dirty car with a pressure washer. I have a 2500PSI washer & it does not get all the dirt off like a brush or sponge will. I use a 5000PSI washer to clean the boat bottom & still need to use a scubbing pad to get the stubborn marine growth off.
For cleaning the rubber roof I have never used a pressure washer. Never had access to one when doing it. I do use a brush & have used a scrubber without any ill effect on the material.
So, yes, I would try a pressure washer, keeping power of the washer & distance from the surface in mind so as not to do any damage.
2007 Alpenlite 34RLR
spoon059
Jim Shoe wrote:
If anyone climbs up a ladder here at home and complains about the dirty roof, I'll be happy to hand them the long handled brush.
Just sold my 17 year old Nash. Never washed the roof the entire time I owned it. According to the manufacturer, there is no need. The EPDM is designed to chalk off as it wears. The black streaks are the natural process of the chalking.
As far as I can tell, washing only accelerates the process of natural degradation of the rubber...
2015 Ram CTD
2015 Jayco 29QBS
enblethen
Pressure washers are not a good idea. It is very possible that it would slice through the rubber membrane.
My rig has a ladder plus my garage I can step between loft and roof, and I have a ladder to lean up against rig. I then usually crawl around roof to inspect sealant.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ddndoug
Doug
2009 Four Winds Hurricane 33T
F53 Ford Chassis w/Triton V-10
Jim_Shoe
When I'm on the road, rain takes care of cleaning the roof. At home, the RV lives inside a building that I own. If there are streaks on the sides when I get home, I use a long handled soft brush and a hose to remove them while I'm washing the bugs off the hood and overhang. The only time I've ever washed the roof was at an RV park that had a hose attached to a water pipe and a moving platform to climb up on. And that was in Yukon Territory on my way to Alaska. And the roof wasn't that dirty.
Retired and visiting as much of this beautiful country as I can.
Veebyes
The same road dirt & soot from the road that gets on the sides falls on the roof. I believe in the KISS principle. Start at the top & use the same stuff all over. Mequires auto/RV soap in the pink bottle.
Twice a year the roof gets a dose of one of the rubber roof conditioners right after a cleaning. 8years old, far from being stain & mark free but looking decent & not dried out.
tbred
Valkyriebush wrote:
TPO roof, Murphys soap oil is what I use.
X2
2012Coleman
I just cleaned my roof - I usually use spic & span but had run out. I saw a full bottle of the spray roof cleaner I bought at CW when I didn't know any better, so I used it as I didn't feel like going to the store at that moment. I was amazed at what a good job this stuff did. I may just make it my go to product.
2018 RAM 3500 Big Horn CTD
Treefrog
former post should have read:
"I haven'tn't noticed roof streaks"
2000 Country Coach Intrigue 36' 350 Cummins ISC
2015 Lincoln MKX
FMCA 351235
Look for us at Civil War Reenactments and the SCA.
Treefrog
Simple Green for me, diluted with water per instructions, on my fiberglass roof. I scrub with a long handled brush (so I can stand up to work) and rinse. I have not noticed streaks.
I have noticed wax stripping, probably because once the roof is dry I put a coat of wax on it.
If concerned about streaking from the roof, I'd try washing/waxing the sides first, after which the roof generated streaks should simply rinse off.
2015 Lincoln MKX
FMCA 351235
Valkyriebush
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
malojeer
I just found powder form Spic N Span here in Louisiana at Stine's Home Improvement 5.99 for a 27oz box. You can order online at www.stinehome.com
