โFeb-18-2017 06:56 AM
โMar-16-2017 08:23 PM
pconroy328 wrote:
Just an update - I pulled the stove apart, cleaned the electrode and connections. No help. I shimmed the electrode up a it higher to the burner and I could get it to spark about 1 out of 4 times. Better.
A little looking, reading and it seems like it's not a replaceable item; the electrode is part of the burner assembly. But, I found a new one on eBay for $15. I've ordered it and will report on if it fixes the issue.
โMar-16-2017 02:59 PM
โMar-15-2017 08:17 PM
โMar-15-2017 03:33 AM
โMar-09-2017 09:38 AM
โMar-08-2017 08:40 PM
โFeb-27-2017 06:44 PM
โFeb-27-2017 05:46 PM
โFeb-23-2017 07:47 AM
โFeb-19-2017 05:53 AM
dakasa47 wrote:
Hello,
One time we were having trouble with one of the burners lighting. Turns out a spider had weaved a web inside the pipe that led from gas to the burner. We were told by RV mechanic we had called it could have led to a serious fire if we hadn't found it.
โFeb-18-2017 02:50 PM
โFeb-18-2017 11:44 AM
MikeInOregon wrote:
I had the same problem with one of our stove-top burners. I think the igniter had gotten dirty, probably from a pot boiling over. I cleaned the igniter ends with fine grit sand paper and the burner worked normally again. The igniter didn't need to be removed. I lightly ran the sandpaper over the end of the igniter electrode while still attached on the stove.
โFeb-18-2017 10:24 AM
โFeb-18-2017 09:02 AM
