Superglide Hitch / Capture Plate Question
Ron3rd
Can you temporarily use the Superglide slider hitch to tow a 5er without the capture plate installed on the pin box? Would only be needed to tow a 5er about 50 miles.
Equilizer Hitch
Honda EU2000
17 REPLIES 17
Ron3rd
Thanks for all the info folks, much appreciated.
Equilizer Hitch
Honda EU2000
C.B. wrote:
You can tow without a capture plate if you stop the sliding action of the Superglide hitch.
This is what I use on my 16K Superglide.
Slide Stop is placed between turntable ways.
Tightened in and jam nutted.
With Slide Stop installed towing without capture plate can be done.
Sharp turns must be avoided so as not to take out rear window of tow vehicle!
C.B.
This is the solution..... As long as you STOP the head from sliding, it is perfectly fine to tow like that... I made up something similar to the poster above, but with minor differences.... Now I have a Long Bed and new B&W and don't have to worry about that anymore !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
CarnationSailor
You could make delivery by the dealer part of the deal.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
2112
When I bought my Superglide the dealer ordered the wrong plate. He locked the hitch from sliding with what he called "slide locks". I thought he got them from Pullrite. They looked something like this:
He clamped them here:
Then tighted up this bump stop:
When I returned to have the plate installed and reconfigured, he noted he didn't grease the hitch surface and it got scarred up:
I towed about 600 miles with my slide locked as described.
I like C.B's setup better
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
C_B_
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
Ron3rd
Good info. Thanks OB
Equilizer Hitch
Honda EU2000
Old-Biscuit
Ron3rd wrote:
Bird Freak wrote:
NO! Don't try this unless you can block the slide from moving. When you make a turn the 5th wheel will turn and slide but not the way you want.
You are asking for a lot of trouble.
That's the answer I was looking for. You need the capture plate, but why?
Thanks Bird.
I'll come up with a capture plate before I move the rig.
The Capture Plate is attached to the trailer's pin box skid plate. When hooked up into your SuperGlide hitch and ready to tow, it isolates the rotation of your trailer's king pin in the hitch. Movement and rotation is then transferred to the automatic cam action of your SuperGlide hitch
Short animated video of how it moves
Ron3rd
Thanks Bird.
Equilizer Hitch
Honda EU2000
Ron3rd
Walaby wrote:
That's the downside of the Superglide. Pinbox specific capture plate.
Didn't realize they had a multi-fit and a universal though, so maybe you could buy a universal plate and it would work.
If you don't have one, who knows how it will turn since the hitch will slide AND it will rotate with king pin.
If your 5er has the same pin box as your son's then yes, you can use his capture plate. Easily removed. But before you try, make sure you have same pin box, or his model will also work for yours.
Mike
Thanks for the info.
Equilizer Hitch
Honda EU2000
Ron3rd
Old-Biscuit wrote:
Per the SG website
"A Capture Plate is a required component of the SuperGlide fifth wheel towing system"
There are 24 'specific' capture plates, 2 Multi-fit capture plates and 1 Universal Plate
Capture Plate Chart
Yes, I read the same thing. Thanks for the info OB.
Equilizer Hitch
Honda EU2000
Walaby
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Old-Biscuit
Per the SG website
Capture Plate Chart
12th_Man_Fan
Well you have had two people say no so I would suggest you listen to them but the capture plate from your son's rig should fit if it is not bolted down.
Good luck I would not want my advice to cause a problem.
You could chain the slider to the front of the mount where it would not be able to move. That would also be a option.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Bird_Freak
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
