TANK IDEAS
Jebby14
Hey all. Im fixing up my new to me tt on the cheap. it has no potable water tank or pump but the gray and black plumbing/tanks is fine. I am not interested in installing a large tank and pump (I like the storage that has been created) instead I picked up 2 small battery operated pumps like this http://www.princessauto.com/en/detail/battery-operated-pump/A-p8555765e I am looking for 2 'tanks' to put these into. was thinking culligan type bottles at first but thinking about it more im thinking id like a screw on cap for transporting it. any suggestions for something on the cheap?
Q: Whats brown and sticky???
A: A Stick....
10 REPLIES 10
rockhillmanor
Horse Trailer Products Websites or look up a local horse trailer dealer in your area and ask to see a catalog.
Quality products and NO RV inflated prices for anything you need for a TV, TT, FW or LQ.
They make triangular corner water tanks that don't take up a lot of room AND they make lay down tanks for pickups too.
Look up horse trailer supplies. Horse people have a plethora of products available to them for carrying water on board in their trucks, TT's and LQ's. They will have all the different pump set ups also along with gravity feed.
18,25,39 gallon tanks etc. We do a lot of venues without water where we have to bring our own water!
https://www.valleyvet.com/c/livestock-supplies/trailering/trailer-watering.html
https://www.horseloversoutlet.com/18_Gallon_Upright_Slant_Load_Water_Caddy_p/ftc-18sl.htm
http://www.horseloversoutlet.com/25_Gallon_Slant_Load_Stand_p/ftc-slst.htm
http://www.statelinetack.com/item/high-country-half-moon-lay-down-water-caddy/BSS10/
wing_zealot
never mind - wrong post
SoundGuy
Can't beat 7 gal Aquatainers ... inexpensive, made of food grade plastic, large screw cap with tap, screw on vent cap, and cube shaped so they store easily. I carry four in the back of my Avalanche whenever we're camping and use 'em to collect potable water as I need it and later pump it into the trailer's FW tank.
2012 Silverado 1500 Crew Cab
Merrykalia
When we had our popup, I used two of the 5 gallon "bladders". They didn't take up any room when empty, but held enough water for us for 3-4 days.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
sh410
Bring lots of D cell Batteries.
Jebby14
cool thanks guys. same things I was thinking of. as for the pumps. wont be drinking the water. they will be filling the crapper and letting us wash our hands so im not worried.
A: A Stick....
marquette
The small pop up had used a standard 5 gal water can. It had a "special cap" that was basically a regular screw on cap that had been drilled out and a rubber grommet put in it that the water hose went through. I'm sure one of the standard blue 5 gal water containers could easily be modified the same way.
beemerphile1
I don't think those pumps are approved for potable water.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Dakota98
Walmart
They have 5-gallon water jugs for camping purposes
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
RedRocket204
VP Racing Sportsman Container - clear
5 Gals capacity
*FDA approved for water storage
I love me some land yachting
