Jan-28-2016 07:10 AM
Feb-02-2016 12:45 AM
Feb-01-2016 09:14 AM
gatorcq wrote:
There are certain requirements for TWH
The Atwood requires the following:
1.5 GPM from each faucet = so you must measure
Temperature differential = 60 degrees. meaning water going in is 30, water coming out = 90.
And yes they work very well WHEN you stick to the requirements and they do not use more LP. Your best way is to call the manufactures and ask for technical support. They are more then happy to explain to you how there system works and what the requirements are. I did just this, and new that the shower head would not meet the water flow requirements. I was happy to have talked to TS. Many people spout what they read on the internet. That is one reason I try and call the manufacture and discuss the requirements of there product.
Jan-31-2016 05:19 PM
Jan-31-2016 01:41 PM
Jan-31-2016 01:32 PM
Jan-31-2016 10:30 AM
72cougarxr7 wrote:
Most of the complaints are about the cheap manually adjustable units. These have 2 knobs, 1 to adjust the gas/flame and the other to adjust the water flow. Any changes in water pressure or inlet temp will change the temperature of the water coming out of the unit.
What you want is one of the computer controlled, self modulating units. The computer senses inlet temp and flow rate and automatically adjusts the flame to give consistent outlet temperature.
You very much get what you pay for when you buy a tankless water heater!
Jan-31-2016 07:05 AM
Jan-30-2016 12:08 PM
Jan-29-2016 10:58 AM
Jan-29-2016 10:41 AM
Jan-29-2016 09:39 AM
Jan-29-2016 06:40 AM
lawnspecialties wrote:
I know these are still new. But not a whole lot of reports on them yet.
Does anyone have a tankless water heater on their camper? If so, how do you like it?
I must admit, we've never had any complaints for the most part from traditional water heaters on a camper. But if something is getting better, I'm open to change. Just not sure if it is better.
Jan-28-2016 10:08 PM
Porsche or Country Coach!
Jan-28-2016 07:52 PM
