Tires are 2009 made in Mexico should I get new?
2lazy4U
Just bought a used trailer. The tires look brand new, even the sidewalls, but the date stamp says late 2009. Since the trailer is a 2010 (hardside popup Chalet, weighs 1500 lbs.), they must be the original tires, I would guess. The guy I bought it from said he'd had it a couple of years and maybe used it a half-dozen times and the original owners had used it twice. There's no obvious sun damage. Do I need to replace these?
12 REPLIES 12
JWRoberts
Yes
TyroneandGladys
IMHO no matter where you live replace tires every 6 years. Because we live in the Phoenix area we replace when the tire turn 4.
Tyrone & Gladys
27' 1986 Coachmen
gypsmjim
My son's tires went in 4 years, with garage storage and proper maintenance. They looked fine when we left - 300 miles down the road they disintegrated.
My tires will never go past 3 years.
2015 Jayco Flight SLX 195RB
Permanently set up on a beautiful mountaintop retreat in Southwest NYS
Bob___Ann
Buy new and enjoy your trip. If you have a blow out the body damage will far exceed the cost of the tires. Also your safety and others safety on the road is most important.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
Miles_Away
A set of new MAXIS tire should be at the top of your shopping list.
M & M :C On the road again!
2007 GMC 3500-SRW-Duramax-longbed-4X4
2008 Keystone EVEREST 348R 5th wheel
2002 SUNDOWNER gooseneck horse trailer
atwowheelguy
Beware of five year old Nankang trailer tires.
2013 F150 XLT SCrew 5.5' 3.5 EB, 3.55, 2WD, 1607# Payload, EAZ Lift WDH
Toy Hauler: 2010 Fun Finder XT-245, 5025# new, 6640-7180# loaded, 900# TW, Voyager wireless rear view camera
Toys: '66 Super Hawk, XR400R, SV650, XR650R, DL650 V-Strom, 525EXC, 500EXC
rk911
I would...pronto.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
2lazy4U
They're 14 inch and the GVWR is around 2500, single axle, but I can't imagine weighing it down that much. I travel pretty light.
JIMNLIN
2lazy4U wrote:
Well, I already pulled it about 400 miles to get it home. I guess I better not press my luck any further.
Anyone have suggestions as to what kind to get?
Depends on what size tire you need.
What is the trailes GVWR ??
I use 44-51 psi P tires on all of my small 7k and under trailers with single axle or tandem axles. Their are no speed restrictions and they last for years without the usual ST tire issues.
old_guy
mine is a 2009 and I got new tires AND had the bearings replacked
2lazy4U
YnotTurbo
Yes,,,get new tires before you go on your first trip. They are now 7 years old and you may not see the dry rot.
Navy Chief (Ret.) Still working. 2019 Ford F350 Lariat, 4:10 Geared and 935 lbs. of Grunt..., 2011 Mobile Suites Lexington
