Emblethen - Going from memory since MH is in storage lot, I don't remember amber turn signals. I think the MH tail lights are LED and there is what I consider the typical looking tail lens plus about midway high, on each side, a 6-8" vertical (narrow) lens and the MH turn signal activates both the lower and upper lens. I don't know what the brakes turn on since I'm single and can't push the brake pedal and see the light 30' behind me. As to your link - well those diagrams sure passed me by. Thanks for the time estimate though.
WyoTraveler. Sorry but my pre retirement career included nothing technical in these areas and with good reason. I think what you are referring to has a probe on the end??? and I'd probably insert that in the wrong place
๐ .
Othertonka - I think a hitch shop is in my immediate future. The car also came with a Roadmaster braking system. I think I've figured out how that operates and I've found the brake away connection but, as above, I'm alone and I'm thinking the hitch shop (which is an authorized Roadmaster, Blue Ox and others installer) can also verify for me at the same time that the supplemental braking system is wired right to the MH and that my understanding of how it is hooked up is accurate. A hitch shop's hour would probably be cheap insurance for me that stuff is operating as it should.
www.putt10.net
