โMay-24-2013 06:54 AM
โMay-24-2013 03:52 PM
โMay-24-2013 02:59 PM
jferre9570 wrote:
I know of at least one instance where the pipe down into the tank wasn't cut short enough; as liquid built up in the tank, solids could not free-fall into the tank. You should be able to see this condition if your connection is straight down.
โMay-24-2013 02:43 PM
โMay-24-2013 02:16 PM
โMay-24-2013 01:39 PM
โMay-24-2013 12:37 PM
HappyKayakers wrote:
Without knowing your normal dumping procedure, I would suspect a poop pyramid. You might want to try one of these.
On edit: If the toilet burps on every flush, even after dumping, the other possibility is that the vent pipe extends too far into the tank.
โMay-24-2013 10:20 AM
โMay-24-2013 10:07 AM
โMay-24-2013 10:01 AM
Lowcountrydupree wrote:
Sorry for lack of info. It does not drop straight down into the tank. The drain line has a elbow making a 45 degree turn then runs about a foot and half before dropping into the tank. I am getting a burping like gulp when flushing.
โMay-24-2013 09:40 AM
โMay-24-2013 09:10 AM
โMay-24-2013 09:00 AM
โMay-24-2013 08:51 AM
beckid wrote:
Sounds like the very same problem we have...our toilet has a pipe that runs sideways at an angle and into the holding tank. I think paper and solids get stuck in that pipe and don't actually make it to the holding tank. I have a clear tube at the end of the sewer hose so I can see whats coming out when dumping, and the last time we dumped after the weekend I saw no paper or other solids coming out - even though we did the black water flush (cha-cha-cha)- so now I'm worried. I put 5 gallons of water down the toilet along with a blue drop-in that helps dissolve, and some boraxo. I hope this solves our problem the next time we head out - maybe it will solve your problem too. I'm taking a yardstick just in case. Seeing as we will be out for 17 days I'm a little concerned.
โMay-24-2013 08:17 AM
