Tow/Camper connected
R_E_Baird
Anyone's opinion...when towing a camper and stopping overnight at a hotel, do you leave the electrical connected to the camper or disconnect? And why?
Jackie & Roland
Jayco Pinnacle 36FBTS
2019 GMC Sierra K3500
24 REPLIES 24
Terryallan
In truth it all depends on your brand of Tow vehicle. I have a Ford. So, I don't have to disconnect. Ford only energizes the trailer when the ignition switch is turned on. It can sit hooked up forever, and the Tt will not bother it one little bit.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Muddydogs
cmcdar wrote:
I stay in my camper overnight at a Walmart close to the interstate.
I have never disconnected the camper from my truck. This would be 15 or twenty times now.
Your mileage may vary...
In general you won't ever have a problem leaving the trailer connected. The one time you have a trailer battery issue and don't realize it and the trailer runs down the truck battery leaving you setting in the parking lot with no juice will be the time you wish you disconnected the trailer. Its no big deal setting in a Walmart parking lot were you can purchase a battery but some isolated rest stop parking lot could be a slight issue.
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
cmcdar
HTT: 2007 R-Vision Trail Cruiser c191
TV: 2010 Nissan Titan Pro4X Crew Cab
path1
R.E.Baird wrote:
Thanks. I forsee me forgetting to reconnect only to discover this mashing on the brakes only to realize it running through the vehicle in front of me.
You're kidding right?....You don't do a "pre-trip"?
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
DutchmenSport
I disconnect.
R_E_Baird
Jackie & Roland
enblethen
Your GM does not have a relay to isolate the trailer from the truck. Fords for example has a relay to disconnect the charge line from trailer connector.
I would suggest adding a relay so it would disconnect rather then having to pull the trailer connector.
A relay wired as shown in the instructions would serve you well.
Relay
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
coolmom42
Disconnect, so as not to drain the tow vehicle chassis battery.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
R_E_Baird
Thanks. That's my concern also, at least one.
Jackie & Roland
morphrider
I have never done an overnight, but I always disconnect from TV if hooked up at my house getting ready due to power draw from TV battery. Don't want that to go dead.
