โMay-06-2016 01:52 PM
โMay-13-2016 01:51 PM
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
โMay-12-2016 09:51 PM
jake2250 wrote:
Hmmmmmm so your saying that based on your ownership of less than a dozen half ton trucks,,The one ton is basically the same vehicle??
Yeah maybe that it carries a license plate,has headlights and a horn.
And if I were to buy a newer F150 I would be getting the heavier frame,springs differentials,transmission, cooling package etc etc that comes with a one ton truck???
Just because Ford put a turbo on a six cylinder does Not make it a F350,, hell they can even call it an HD and it still wouldn't be near an F250!!
Switching to an aluminum body and giving you a couple of hundred more cargo pounds to haul does not make a half ton truck a one ton vehicle.
I believe the running gear and frame and suspension dictates that!!
Just for giggles,, park your half ton next to a one ton,,,,,Hey something is different,,, for one thing kinda obvious,,,stance and lug nuts..
goofy huh??
โMay-12-2016 08:37 PM
โMay-12-2016 07:10 PM
โMay-12-2016 06:17 PM
Headed West wrote:4BIGAL wrote:
HeadedWest, can you tell me your unloaded mileage between the 150 and 6.2L 250? What engine did you have in the F150 and what rear end ratios. Thanks.
Sure my 150 got between 19-21 mpg on the hwy unloaded. My 250 struggles to get 15 mpg on the hwy. That's if I keep it under 65. I average right now 12 to 13 mpg unloaded normal driving. I pulled my trailer about 45 miles and got 7.9 mpg. and that was during a storm here. I hope to avg 9 mpg going to Maine. HOPE!!!
โMay-11-2016 11:06 AM
Grit dog wrote:humblerb wrote:IdaD wrote:
That's right at or just a bit over the limit of what I'd personally want to try to tow with a half ton, but lots of guys on this site are doing it and report good results. I guess I'd say a lot depends on how you use the trailer. If you don't leave the island much and mainly just camp fairly close to home I would be more apt to do it than if you plan to haul it on longer trips into the Rockies regularly.
I definitely would not spend the money on an F250 since you have an F350. If you want an F250 it would be much cheaper to simply remove your overload springs.
He was asking about a New F150 or a New F350. Looks like he is going to buy a new vehicle, but wanted advice on F150 versus F350. To me, the F250 is the best of both worlds - downgrade from the current F350, but enough truck to not have to ask if he would be comfortable pulling his rig.
But it's basically the same truck as a 350, so this is really not a valid answer.
A new or newer F150 will pull your trailer smartly if you choose to go light duty. I've beat the tar out of at least 10 F150s over the last 20 years towing and hauling as much or more. I'm not a Ford guy but they're tough trucks and the last chassis (haven't had a new '15-up yet) is very strong/ stiff frame, great brakes and trans and both the 5 liter and the big Eco boost have enough snort.
โMay-11-2016 10:51 AM
โMay-11-2016 10:49 AM
โMay-11-2016 04:44 AM
โMay-10-2016 08:05 PM
jake2250 wrote:smkettner wrote:jake2250 wrote:Seems odd to me. My truck is older (260hp) and my trailer weighs more. Wind and passing semis are never an issue. I just set the cruise and wander on down the road.
I wouldn't tow it with anything less than a3/4 ton, I don't care if that F150 has a blown or super charged 427 in it, its still a 1/2..
I had a 2004 F150 Screw 5.4 HD, I tow a 23' trailer just shy of 5000lbs loaded closer to 6000lbs, Towed it with that F150 for two years,, It progressively got worse and worse. It was actually wearing that truck out,, let alone wearing me out!!
The 5.4 was advertised at 300 HP,,and I can tell you my foot was in that thing ALLOT!!!
After a transmission flush and new Bilstien shocks it was still a handful!! Last trip was the proverbial Last Trip!! Towed in a head wind of 25 to 30 mph, I could barely keep it at 60mph, And god forbid I got passed by a semi,, I was blown all over!!
Got to the camp ground and the wife even admitted,, "Need a bigger truck"
Amazing how the perception is so different.
Do believe I answered Dirtpigs question with my own experience. Learned the lesson and now have a 2500HD with all I need to get from point A to point B with out worry,, My F150 experience differs from yours. I any other poster asks the same question I would answer the same. Also,, I drive over the road trucks,,80,000 lbs, wouldn't do it in a half ton either,, but thats just my perception!!
โMay-10-2016 06:43 PM
โMay-10-2016 04:59 PM
โMay-10-2016 03:39 PM
