โNov-20-2016 03:43 AM
โNov-27-2016 01:50 PM
โNov-27-2016 05:55 AM
burningman wrote:
The truck can handle it, as mentioned the difference between a 3/4 ton and a one ton is virtually nothing. You'll want some springs or air bags, I prefer bags because I use my truck all the time not just hauling heavy and I don't want to ride around in a stiff truck when it doesn't need to be. Overly stiff empty pickups get downright dangerous at even moderate speed on bumpy surfaces.
It's all about the wheels and tires. You're in the territory of either 19.5s or duals.
The rear axle rating on the sticker assumes stock wheels and tires, which are the main limiting factor. The axle itself is good for a lot more and it's the same parts that are in the dually axles.
โNov-27-2016 05:44 AM
โNov-26-2016 05:11 PM
โNov-22-2016 06:33 AM
โNov-22-2016 06:04 AM
coolbreeze01 wrote:clemp wrote:
Just purchased a F250 Diesel, then I bought 42ft Road warrior, I'm thinking I can't haul it with that truck. Any thoughts
I'd be looking at 4500 and 5500's. Good luck.......
โNov-21-2016 06:59 PM
โNov-21-2016 12:32 PM
โNov-21-2016 12:18 PM
โNov-20-2016 08:09 AM
Cummins12V98 wrote:
Bags and 19'5's "it will tow just fine". ๐
โNov-20-2016 07:06 AM
โNov-20-2016 06:54 AM
โNov-20-2016 06:49 AM
โNov-20-2016 05:02 AM
