Tree sap
Goldbrick
Can anyone tell me what detergent or cleaner is best for removing tree sap from roof and upper side walls?
15 REPLIES 15
imgoin4it
I used alcohol after getting lots of tree sap on our coach. An RV park cut off low hanging branches so coach would fit under the tree. What a mistake that was,never again. Alcohol worked great.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
soos
try hand sanitizer. you will be amazed at the results.
Sue
soos-ontheroad.blogspot.com
Fulltiming since 2009
2012 Mobile Suites 36 TKSB4 pulled by a
2011 Ford F450
2005 Lance 1181 TC- our Vacation Home
Crazy_Ray
RainX works good too at removing goo
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
Padlin
Watch this.
Sap removal test
I've been using alcohol with good results. I Imagine it removes any wax too.
Happy Motoring
Bob & Deb
W Ma.
12 F150 HD SCAB EcoBoost LB 4x4
14 Escape 5.0 TA
path1
Your sig line says Mich. Wait for a good freeze and peel off with old credit card.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
Deb_and_Ed_M
I had good luck using Simple Green on a gunked-up roof after our pop-up trailer sat under a tree (Chinese Elm) for months.....
Ed, Deb, and 2 dogs
Looking for a small Class C!
doxiemom11
Depends on what type of roof you have. Some should not have any petroleum products used like WD40 would be.
Ours is aluminum and we use Awesome with great results.
DrewE
Pine pitch/sap (and that form spruce and similar softwoods) can be softened and removed using some sort of oil-based substance. A pat of butter works nicely on one's hands, and I would think would work equally well on an RV. Of course you then have to wash the butter off, but soap and water and a bit of elbow grease should do that.
1492
Moderator
Moderator
Moved from Forum Technical Support
BluegrassBill
X2 on WD40
Bill & Kathy Francis
95 Itasca Sunrise 29RQ,P32 454 Chevy, Banks,ECM chip.Safe-T-Plus, Bilsteins, Super Steer Bell Crank, Stewart Stage 1 Waterpump, Severe Duty Fan Clutch, OilGuard Bypass Filter, Coolant Filter. Rear Tracbar. 1-5/8" Front Swaybar.
brirene
After sitting under the pines at Custer last week I'll need to tackle some pine sap too. Really hoping it comes off easy.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Bumpyroad
in a previous thread tree sap removal was discussed for trucks. I found goof off worked the best.
bumpy
DutchmenSport
I have found that WD-40 does some amazing things for cleaning gooie stuff. You might give it a shot (literally)!
Goo Gone (http://googone.com/) is also pretty good on stuff too.
But on the roof, I'd just forget it.
Houston_Remodel
First try the hottest water possible, then do what Tom said.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
