โJul-23-2020 07:59 PM
โAug-07-2020 06:46 PM
โAug-05-2020 10:29 AM
โAug-05-2020 08:22 AM
Mike134 wrote:
Gosh you folks bring a lot of **** in your campers. Wife and I can camp for a week and starting out loaded with clothing, groceries and "usual" camp stuff the camper weights 700lbs more than when it left the factory. What are you bringing to add 1500-2000 lbs?
โAug-04-2020 12:29 PM
โAug-04-2020 12:24 PM
โAug-04-2020 09:55 AM
โAug-03-2020 11:53 AM
โAug-02-2020 08:25 AM
โAug-02-2020 08:00 AM
โJul-26-2020 10:42 AM
โJul-26-2020 05:48 AM
op wrote:
Please educate me if it doesn't seem safe for my truck.
โJul-26-2020 05:38 AM
โJul-24-2020 07:22 PM
โJul-24-2020 01:30 PM
Heybro wrote:CharlesinGA wrote:
Your hitch weight is unrealistic. Optimum is 13% of the trailer weight. So if you take the dry weight (which you will never see) and multiply by .13 you get 783 lbs. If you use the max gross weight, its 1196 lbs.
Figure about 110 lbs for propane, take the water capacity and multiply by 8 lbs per gallon, then take all the cookware, grill, dump hose, potable water hose, power cord, etc and clothes and personal stuff, extra shoes, etc, it adds up fast.
A realistic tongue weight is more like 950 to 1000 lbs for your situataion. Simply put, your truck is no where close to being capable of doing this.
You need to gas up the truck and go to a scale and spend the $12 or so and weigh it, then you can have some real numbers to work with. Towing capacity is calculated by the manufacturers using a flat bed trailer loaded with (take your pick) bricks/railroad iron/lead/etc and is not representative of towing a big box down the road that reacts to wind and buffeting of trucks. Its simply what the engine, transmission, and rear axle are capable of pulling, and the brakes are capable of stopping, without breaking the first time you tow.
Charles
Charles
Well the 595 lb dry hitch weight is what it says on the manufacturer website which would put the tongue weight around 9.8% of the dry trailer weight. Are you suggesting that they have incorrect numbers posted?
Also, I dont see how you came up with the tongue weight at 900 to 1000 lbs for my situation. How do you figure that? It realistically seems like It would be around 750-800 lbs for my loaded tongue weight.
