Aug-20-2022 06:34 PM
Aug-25-2022 04:12 PM
JRscooby wrote:Matt_Colie wrote:
Gary,
I don't know where you are in Michigan, but we have bearing stores all over the place. What you do need to do is get all 5 numbers. I don't know about your unit, but it may well have different numbers for the inner and outer bear sets and each of those is two part numbers. The seal is a third.
I hope the spindle isn't damaged. That often happens when a bearing goes bad.
When you get all 5 numbers, use a marker to write them inside a cabinet door so you will have them next time.
Matt
I carry all bearings and a seal to do 1 wheel. Plus in the garage I have enough seals to do all my trailers, and shoes springs and magnet for 1 wheel per trailer. If I decide it is a nice day to service a trailer I don't want to hunt parts.
Aug-25-2022 04:05 PM
larry cad wrote:
I predict we will not hear from the OP on this again.
Aug-24-2022 02:38 PM
Matt_Colie wrote:
Gary,
Matt
Aug-24-2022 12:35 PM
Aug-24-2022 07:09 AM
Aug-24-2022 06:53 AM
Aug-23-2022 07:38 AM
Aug-22-2022 08:10 PM
Aug-22-2022 08:06 PM
JRscooby wrote:
Look real close at edge of bearing. Most times there is a name and number. If can't find that, take the races to a trailer parts/repair shop. Note; if you don't tell the bearing it is going on a RV, it will never know. Much more likely to get what you need from a shop that does not fix toilets and stoves. You are looking for trailer parts, not RV parts.
Aug-21-2022 11:07 AM
Aug-21-2022 08:37 AM
Aug-21-2022 07:31 AM
Aug-21-2022 04:37 AM
Aug-20-2022 09:33 PM
