โMay-10-2020 07:08 PM
โMay-14-2020 05:30 PM
โMay-14-2020 06:40 AM
All I could afford wrote:
Lynnmor.... I do have an exposed fill cap and exposed vent screen like in the picture you linked to. But mine does not have the little cap tether strap, it just has a small 1/8!inch hole in the center. I used to assume that was to help venting, but after seeing your picture Iโm thinking that the tether strap broke off mine sometime before I bought the trailer. I will be up by it probably tomorrow afternoon and Iโll get a picture.
โMay-13-2020 08:46 PM
โMay-13-2020 07:03 AM
So here are the pictures of what I shook out of the vent hose into a coffee mug
By the way, I had meant to say a cup of bleach mixed into my 30 gallon tank, not a quart, but that still sounds like double the recommended strength. Better than 8 times the recommendation though.
The yellow powder was all at the tank end of the 2 foot vent hose, right at the fitting that is molded into the tank itself.
โMay-13-2020 05:59 AM
โMay-12-2020 10:30 PM
โMay-11-2020 09:07 PM
โMay-11-2020 08:14 PM
โMay-11-2020 07:29 PM
โMay-11-2020 06:31 PM
โMay-11-2020 03:38 PM
Iโve owned my 1999 trailer for 8 years now. I start every spring with a flush out of the pink antifreeze in the plumbing, followed by a sanitation of the fresh tank and pipes with a quart of bleach mixed into the full 30 gallon tank.
Last week when I went to service the system, I noticed my half inch diameter clear vent tube was clogged with dry yellow powder for the first 2 inches coming from the tank. I removed the hose and tapped the powder into a white coffee mug before washing out the tube and reinstalling.
Could this be from filling up the tank in mountain areas with high mineral well water? Should I be concerned? Iโm having trouble trying to attach a photo today
โMay-11-2020 03:11 PM
cptqueeg wrote:
Pine pollen perhaps?
โMay-11-2020 05:09 AM
โMay-10-2020 08:44 PM
mobeewan wrote:
I'll second on the pollen.
If you don't have a good water fill connection enclosed behind a hatch or door, everything that gets washed down the side of the trailer when it rains can get in the vent tube or the water fill port if it doesn't have a cap.
I had my trailer in to a dealer to get the roof Corners resealed because the caulking was looking bad. While I had it there I also paid for them to wash and wax it. About a week after I got it back I found liquid wax that was sprayed on it in the fresh water fill hose. There was pink wax residue from the spray on wax that ran down the side of the trailer and gotten into the fresh water fill hose.
The water fill port looked similar to the shorepower mouse hole with the same type of flap that snapped closed over the opening. I wasn't too happy about that one. I had to remove the fill hose between the outside hatch and the tank and scrub it out with a bottle brush and Dawn then reinstall the hose. I'm not sure if anything got into the tank but I flushed it a couple of times just in case.
Within a month I replaced the cheap water fill port with a lockable hatch type after I found sediment that looked like dirt in the hose again after I had cleaned the wax out. I figured it was dust and dirt that rainwater had carried down the side of the trailer and it had weeped into the cheap water fill port.
