Anode Rod Wear
Mr__C
What would cause severe wear to the rod at the connection end? Almost no wear on the rest of the rod. I use teflon tape on the threads. Two brand new rods, two years in a row.
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
22 REPLIES 22
StirCrazy
Moderator
Moderator
Pbutler97 wrote:
Latner wrote:
Mr. C wrote:
It's this rod. I'll just plan on buying a new one before camping season.
https://www.amazon.com/gp/product/B075MNVPSX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
lots of life left for those two rods
Yep, if thats from one season of use it looks like they would be good for another 8-10 years, but if folks feel better wasting money every year for a new rod more power to them. Those rods will perform just as well as a new one.
I would change them at about 50% use. there cheep insurance.
its a little deciving how they wear out, mine look simular to his after 1 season. after the next they are about 50% gone. it also depends where I go camping nd what the water is like there.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
C_Schomer
Changing rods sure beats changing large heaters and tanks every 4-5 years! Craig
C_Schomer
^^^ I agree with everybody. I've changed a bunch of rods in commercial heater/tanks and sometimes they do that. I always change them, as long as I have the water drained down. Craig
Pbutler97
GaryUT
That's what the rods from my heater look like after 1 year.
They are not expensive so I just put in a new one in the spring.
I use the Suburban rods, they seem to hold up better.
Suburban 232767 Anode Rod
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
enblethen
Here is a good article on anodes
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Latner
fj12ryder
MFL wrote:
Those rods look good, if each had a years use. You can easily get another year of use out of either of those. Looks like 80% or more left, and should be able to use down to 25-50% with still good protection.
Your money, you decide, but changing to aluminum not necessary.
Jerry
I agree, I switched to magnesium because I was getting a lot of the slimy aluminum compound in the bottom of the tank. Changing to magnesium took care of that issue.
Howard and Peggy
"Don't Panic"
ktmrfs
BB_TX wrote:
I agree that those rods are still good for another year.
I tried changing to an aluminum rod once. After two years it still looked new. Didn’t seem to be doing its job so I switched back to magnesium.
If you have very hard corrosive water that quickly eats magnesium anode rods, then a switch to aluminum is reasonable. If it takes years to do in a magnesium rod, then the magnesium rod is the best choice and provides the best protection.
2011 Keystone Outback 295RE
RAS43
MFL wrote:
fj12ryder wrote:
Ours always erodes quickest nearest the threads, which I believe is the reason: closest connection. But just a guess.
Mine too, and same guess.
Same with mine. I continue to use it as it will still sacrifice for a time.
Mr__C
Thanks for the advice. I'll just reuse the better of the two.
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
BB_TX
MFL
Nomad II
Nomad II
Jerry
enblethen
You may want to switch to an aluminum rod. Keep an eye on it to see if decays more evenly.
magnesium anode link from OP
Bud
USAF Retired
Pace Arrow
Type a product name
