โOct-07-2016 05:42 PM
โOct-08-2016 09:44 AM
Bud
USAF Retired
Pace Arrow
โOct-08-2016 09:41 AM
โOct-08-2016 09:28 AM
โOct-08-2016 09:21 AM
jetcare wrote:
The thermostat with the round wire terminal soldered to it is for the 16 gallon EXT water heater and is set for about 155 degrees. This is the wrong thermostat for a 6 gallon unit.
jetcare wrote:
You mentioned a kit that contained two identical looking thermostats. This is the kit you need. If you look at the back of the thermostats, one will say 62C and one will say 80C. The 80C is the ECO.
โOct-08-2016 08:18 AM
โOct-08-2016 05:53 AM
โOct-08-2016 04:59 AM
Old-Biscuit wrote:
ECO and T-stat are both just snap disc devices BUT the terminal/spade connectors are different sizes. ECO larger. So the brown wires only fit the T-stat and the Red wires only fit on the ECO.
Old-Biscuit wrote:
Normal T-stat (small terminals).......Opens at 140*F (controls firing and water temp between 110*F to 140*F)
ECO T-stat (larger terminals)..........Opens at 180*F (always closed unless temp goes too high)
Thermal Fuse (small terminals)........Burns out at 190*F (No DC for anything if it blows)
โOct-08-2016 02:48 AM
โOct-07-2016 10:41 PM
โOct-07-2016 06:50 PM
Bud
USAF Retired
Pace Arrow
