โMar-28-2014 09:43 AM
โMay-18-2014 07:17 AM
โMay-18-2014 04:20 AM
โMay-17-2014 07:04 PM
Chris Bryant wrote:brulaz wrote:
Maybe I should just get one of the hammer crimpers and a bunch of closed-end lugs and do/redo all those connections.
EDIT: or those Fusion solder lugs.
The hammer crimp doesn't impress me at all- a picture of one with clear overheating problems-
Name brand labeled lug crimped with an approved crimper. *Not* heat shrinked, though, just taped.
That's 4/0 cable.
โMay-11-2014 07:42 PM
โMay-11-2014 03:59 PM
Chris Bryant wrote:
I found this by finding a voltage drop in the cable under load- I forget the specifics, but under a heavy load (probably ~300 amps) I had a significant loss, exacerbated by the fact that this system uses 2 volt batteries, so a fraction of a volt per connection adds up.
โMay-11-2014 03:53 PM
โMay-11-2014 03:39 PM
BoonHauler wrote:
I agree with Jeff, the vise idea is a bad one!
โMay-11-2014 11:35 AM
SCVJeff wrote:brulaz wrote:The load is the cause of the heat, but only because the crimp is defective. It should carry the same load as the cable. There are different kinds of 'crimps'. One chould argue that this 'crimp' stretches the metal, not compresses it. A good hex crimp literally compresses and re-shapes the metal itself (think Superman and coal= diamond). If you start making multiple compressions on a vise, I think you stand an excellent chance of fatiguing the metal and splitting it.Chris Bryant wrote:
hmmm, are you sure it was the crimp and not just the load? But yes, too deep a crimp.
I'll be using a vice, not a hammer, so more control. Does somebody have instructions/advice for using these things? Should you do a partial crimp and then rotate?
โMay-11-2014 01:01 AM
โMay-10-2014 05:53 PM
โMay-10-2014 02:53 PM
โMay-10-2014 02:21 PM
โMay-08-2014 05:25 PM
โMay-08-2014 02:27 PM
