Battery voltage drops!!!
bc_canuck
I have a 2015 Jayco Pinnacle with a residential fridge. When I am plugged in to shore power and have fully charged batteries (two of the biggest Trojan 6 volts that I could fit in the battery cases) my voltage readout is 13.2/ 13.3. After driving for 4 to 5 hours my readout has dropped to around 12.3 to 12.4 volts. I thought that it should at least maintain my full charge running off my truck charging system. When we then dry camp overnight my LOW voltage alarm starts to beep usually around 5 am and of course wakes me up. I did not spend 100K to have a very fancy alarm clock. Any suggestions would be appreciated. Thanks .
34 REPLIES 34
MEXICOWANDERER
If I run into something like that now, I smile and start back peddling...
"Lo siento no hablo ingles"
"I'm sorry but I don't speak spanish"
"I'm deaf"
"Soy sordo"
"I'm disabled"
Tengo incapacidad"
The ill-tempered who snap at the hand holding a treat. It's really true "You Can't Cure Stupid".
But note the conversation has drifted and none of this has anything to do with the OP.
What it DOES have to do with is learning about what you're trying to do. I am computer and arduino ignorant and will fight to the death to stay that way. If something bad happens because I chose to ignore the ramifications of ignorance I smile and shine it on. My ignorance either caused a problem or made it worse. Mea culpa. My aged housekeeper in Oaxaca put her hands and frowned. " let me explain something to you senor..."
"All your life information is filling your head. When you grow old your head gets full. At one point or another your head gets full. Then something very unimportant can go into one ear and push something very important out the other ear".
All I know is if I do not educate myself before I buy something (usually very expensive) I am likely to end up screwing myself. Browbeating oneself in a mirror is not good for the ego. A person can be their own worst enemy. Read! Educate yourself! Study!
Gene_Ginny
MEXICOWANDERER wrote:
.... Then he cursed me when I recommended his returning to Arizona or Texas and purchase a used one ton dually. "That isn't the @#$%^&! answer I was looking for!"......
But the salesman said I could tow it just fine. :R That was the answer he wanted .... even if it would have been the wrong answer. :S
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
MEXICOWANDERER
Ooooooooo I like this new Buggati!
Can you drive?
Well, er, ah...
E CAVEAT EMPTOR
Please keep in mind that FEW if ANY recreational vehicles are set up to boondock right off the showroom floor. They are almost pure grade Power Pedestal Princesses. half million dollar MCI coaches with 2 8-D batteries in the early nineties. Wotta laugh! Good until around 2AM.
First mistake was believing Herb.
Second mistake was the purchaser not investigating the issue via the wealth of internet iformation before purchase.
Third mistake was not conducting a shakedown overnight before the trip
I have an ultra-bright (gift) flashlight that is incredible. For twenty minutes. 5-watts and three AAA batteries.
Or the guy who destroyed a 1994 Ford brand new pickup by hauling a 38' Teton trailer? Nobody told him an F150 wasn't a good mate for his Teton. Madder than hell when it played Laurel and Hardy in Manzanillo. The trailer squashed the pickup damned near flat against the spring stops, but sticker in gear and head out. He paid a King's Ransom in repairs before he(un-encouraged) asked for my advice. Then he cursed me when I recommended his returning to Arizona or Texas and purchase a used one ton dually. "That isn't the @#$%^&! answer I was looking for!"
IMPLIED MERCHANTIBILITY is a term folks should acquaint themselves with. When a conflict with reality disproves implied merchantibility then there are consumer laws and legal actions that can be taken.
Something like me purchasing a $15,000 computer server then finding out it doesn't do Windows.
Go figure...
CA_Traveler
mkirsch wrote:
...and if you just paid $100,000 for a rig that came with a compressor fridge, don't you think it would've come set up to actually run it?
Absolutely NOT, but that is the difference between a person that has bought a few cars that mostly do what's stated and an experienced RVer.
I feel compassion for the OP but from what he's posted his rig is not designed for overnight camping w/o utility power. Maybe he can improve the TV charging but overnight stays are going to require utility power, gen, more batteries, solar, etc.
2014 Grand Cherokee Overland
Bob
time2roll
Don't worry the OP did not seem to take to any of the great advice given or look into possible solutions.
Just run the Onan into the night....
mkirsch
Nomad II
Nomad II
Ya think maybe - just maybe a bank of AGM batteries and a high output alternator is outside the realm of intelligenge to obtain ABSOLUTELY TROUBLE FREE REFIGERATION/FREEZING?
Yes and that is why the original post.
You shouldn't have to get a 4-year electrical engineering degree to figure out that you need install 500lbs of batteries, a flux capacitor, and a matter-antimatter intermix chamber to keep your food cold. It should just be cold.
MEXICOWANDERER
I love it when an OP asks definitive coherent questions and they are answered by a raft of arm-twisting personal opinions based on a severely limited experience by one single person. Some companies tried pulling similar stunts on my clients and that is how I made my living - shoveling my way through 1.0% reality and 99% arm twisting opinion. Yes this still makes me cranky. Those that don't like it can sue me. Answer the question first. "My opinion is" follows, and de-fuses the air of hyperbole.
Grumble Grumble Snort
red31
MEXICOWANDERER
Never have tried to use a screen door on a submarine. My heavily insulated force draft 18 cf consumes 58 amp hours in 24-hours. I had to convert and adjust 12 to 24 volts for you. Start engine. 400-amp Niehoff alternator looks at it's task list and laughs it's ass off. Preparation-preparation- preparation. But I will say this seriously - that Samsung has saved me many many thousands of dollars of wasted food and needless trips to distant "gas" plants and replacing wasted food. When I shop I can put a lot of food in that 5-CF freezer and on a 100F day the ice cream comes out rock hard.
I would not go back to gas if someone paid me a thousand dollars and stuck a gun to my head. Ya think maybe - just maybe a bank of AGM batteries and a high output alternator is outside the realm of intelligenge to obtain ABSOLUTELY TROUBLE FREE REFIGERATION/FREEZING? On a hundred degree day even the door shelves maintain 39F and the freezer -5F. Butane fills are reserved for hot water heating but I have a HEAT EXHANGER off of engine cooling with convection circulation with check valve. No can do on a tow rig but I am free forever of the idiocy of substandard food preservation and MIS-ENGINEERED absorbsion manufacturing. I know what pissed off hydrogen atoms do to steel and sheet metal piping is a cruel joke. It takes thought and planning to do a conversion to freon but hey you guys haunt a tech forum so what's the issue? My refrigerator will be trouble-free GUARANTEED just like it has been since 1994. And I am free of worries about Listeria Shigella and Tomaine. Wotta hoot.
RJsfishin
I tried to think it as a funny, but then realized it as just plain ignorance.
RJsfishin wrote:
I can hear the salesman now,......"yes, for 100 thousand, it should work for dry camping"
You do know the reason they make RV propane fridges ??
¡Si!
To hurl out the door. They make great landfill.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
mkirsch
Nomad II
Nomad II
¡Si!
So instead, you put in an amp-sucking inverter-powered residential fridge and scratch your head bald over why the batteries won't hold a charge... Makes perfect sense.
MEXICOWANDERER
Four gauge cable from truck battery to 80 amp breaker, through heater hose insulation under truck to dual pole socket on rear bumper, or near 5th wheel.
Continue on through trailer with dual four gauge to 80 amp breaker then into batteries.
This was the only way I could get my trailer batteries to charge right. Or you could go to the SURE POWER dot com home page and investigate boosting voltage to 80 and sending it through a much smaller wire. The kit ain't cheap.
A salesman will snap your arm in half trying to convince you a Manatee is Marilyn Monroe. Take a BS meter near a car or RV showroom and the sucker will grow legs and go jump in someone's lap.
DrewE
re_tired wrote:
I also checked my truck and see that it has a 30 amp fuse on that wire to the connector. That's interesting. A chart shows you can only get 30 amps at the end of a 10 foot long 12 gauge wire at 12 volts. In other words, if there was a short maybe 25-30 feet away in the RV on that line, it would probably never blow the truck's 30 amp fuse.
That chart must be based on legal/safe limits, not on physical limitations. 12 gauge wire does not have a resistance of 0.04 ? per foot, but rather around .0016 ? per foot. A 10 foot length would have a theoretical short circuit current of around 750A at 12V.
camperguy99
I have a new Thor Tuscany (yes, I know!) all electric motor home. It came with 4 very poor 56# GC2's. I replaced those and added two more (6 total GC2's (@ 67# each) @ 230 AHrs from Samsclub) and now I'm lucky to get by for 24 hours. Depends on how many cups of tea/coffee we boil on the Induction range top. It's something like 80 amps scaled down to a power of 3/5 but only for 6-8 minutes. I should have 3x230 AHrs now but the battery voltage stays below 12 most of the time. Seems to only take a short time for it to be below 12V. Yes, I have a 100 amp converter so with the generator running I get a measured 105 amps going into the battery bank. My current probe shows the 105 amps nearly evenly split on the three battery series pairs. The Cummins alternator is connected with 2/0 wire so I do see good charging going down the road. I see about a 11 amp load (12V battery to inverter) from the 23 cu foot fridge. Not a good boondocking situation! Count on at least 3 hours of generator use a day! Have not figured out where all the power goes yet? Oh forgot, the fridge lights with all three doors open draw about 350 watts!
