Black Tank Dump Valve
When I dump a full black tank, the valve opens very easy, no problem. I flush the tank for 5 to 10 minutes, then I close the valve for 5 minutes to let it partially fill. When I then pull the handle to open the valve again, it is so difficult that I almost cannot open it. Been this way for a couple of years, and now I thought I might do something about it.
I put tank valve lubricant in the tank periodically, but that doesn't seem to make any difference. Any ideas why full it is a piece of cake to open, and after flushing and partially filling, you almost need a gorilla to open it.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
13 REPLIES 13
Update: The difficult operation is not related to flushing the tank or pressure building up in the tank. I dumped the black tank and as usual the valve was easy to open. While dumping and for a total of 10 minutes, I ran water in thru the flush port. Then I closed the valve and tried to re-open it. It was very hard to operate.
I think I am going to try the valve lubricant that you put in the tank one more time, and then, if that doesn't work, probably have the valve replaced.
RLS7201
IAMICHABOD wrote:
I found that lubricating it during a dump as in this video works.
I have used this method for many years to lubricate my valves and have had no problems with them at all.
This Video will show how to do it
I did the same only different. I drilled, tapped and screwed in grease zerks. Then lubed with chassis grease. NO! the seals are NOT rubber.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Durb
Lynnmor wrote:
CarnationSailor wrote:
If I recall correctly, the roof top vent cap is attached to the vent pipe with screws. So it seems unlikely that the pipe slipped down; however, if it did, then the vent cap should be missing. At any rate, I'll check out this possibility.
For some information Google: rv vent pipe slipping
As a test, turn off the black tank rinse then flush the toilet which will relieve any tank pressure. Then, try the valve.
Lynnmor
Looks like a good solution for sure - if your dump valves are exposed and easy to get to. I would have to either drop the coroplast or cut a hole in it, and I'm not ready to go there yet.
Lynnmor wrote:
Durb wrote:
Do you turn off the water to the black tank rinse before opening the valve? Could be the incoming water is building pressure inside the tank and binding the valve.
Good thought. The tank has a vent thru the roof and can only build pressure if that vent is blocked. What can happen is that the vent pipe slipped down into the tank and is now under water, or even worse, resting on the bottom.
I think if this was happening, the vent pipe would also have to be mostly blocked, but not so much that normal usage builds pressure. I could test this by waiting 30 minutes or so after partially filling tank to give it time to bleed off. If it works easily after giving it time to bleed off, then I think this might prove your theory.
jdc1
Add liquid detergent to the tank occasionally.
Lynnmor
Durb
IAMICHABOD
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
LadyRVer
Might try spraying handle/metal rod with silicone. Or probably just need to replace. I did my tank, took me about 3 hours.. but I got it done.
CA_Traveler
Something in the seal dries out over time and then swells with usage? Regardless why not just replace the valve and be done with it?
2014 Grand Cherokee Overland
Bob
