Mar-03-2021 03:49 PM
Mar-11-2021 03:43 PM
BFL13 wrote:
As a sort of rv.net tech issues survey, would you like your converter to have a bluetooth module that you could set the charging parameters Vabs and Vabs timing to any voltage and time, kind of like this? :
Most converters are not adjustable, but do not meet many typical battery charging specs, which can be frustrating. If a solar controller or the charger in an inverter/charger can have this, why not a converter?
Would you use it if yours had it? is the question. Thanks.
https://www.custommarineproducts.com/uploads/1/4/3/7/1437708/using_the_ep_controller_bluetooth_app_1...
Mar-11-2021 01:17 PM
Mar-10-2021 07:30 PM
Mar-04-2021 03:47 PM
Mar-04-2021 03:25 PM
time2roll wrote:
Been 8 years since I set my solar controller. Have not even looked at the settings since.
Mar-04-2021 02:51 PM
Mar-04-2021 01:54 PM
MrWizard wrote:
The solar controller I installed in the Safari is Bluetooth controlled, and I really like having that function,
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
Mar-04-2021 12:20 PM
Mar-04-2021 11:59 AM
time2roll wrote:
If you are in range of BT you can just hit the Wizard if you are so inclined.
I will be out on a hike or fishing while you tend this trivia.
Mar-04-2021 11:33 AM
Mar-04-2021 10:43 AM
Mar-04-2021 09:27 AM
Mar-04-2021 09:10 AM
MrWizard wrote:
Yes if my converter had that ability, I would use it
Mar-04-2021 03:05 AM
