โNov-24-2020 11:41 AM
โNov-26-2020 07:45 PM
BeeBee wrote:
Thanks all for the replies. Is an "ATS" the "transfer switch" ? Is that the switch that switches from DC to AC? Where might I find that in my travel trailer?
โNov-26-2020 12:49 PM
2oldman wrote:Cummins12V98 wrote:Yes.. the screws that attach the 30a cable to the plug. PITA to check, but when they work loose things get hot.
I HIGHLY suggest turning off the AC power and tightening EVERY electrical connection possible. This also applies to cords with twist locks and their receptacles.
โNov-26-2020 11:27 AM
โNov-26-2020 09:11 AM
Bud
USAF Retired
Pace Arrow
โNov-26-2020 08:49 AM
time2roll wrote:BeeBee wrote:
Click For Full-Size Image.
So is it possible there was one loose wire and the heat moved on the bus to discolor the other wires?
โNov-26-2020 03:25 AM
โNov-25-2020 02:05 PM
โNov-25-2020 12:30 PM
โNov-25-2020 11:45 AM
wolfe10 wrote:QCMan wrote:
Odds are they are all loose or were before you tightened them. Loose connections = higher resistance = high temps = burnt wires.
I agree. MUCH more likely that a random power surge causing the excessive heat that destroyed the insulation on all of them.
โNov-25-2020 10:56 AM
โNov-25-2020 10:26 AM
โNov-25-2020 10:24 AM
โNov-25-2020 06:44 AM
dougrainer wrote:Wiggling the wire as you tighten helps too.
I tighten the screws as tight as I can get them. WAIT 30 minutes and then tighten again. Even solid core wire will "settle" a little.
โNov-25-2020 05:10 AM
enblethen wrote:
Transfer switches are not common in trailers and only if equipped with on-board gensets.
I would suggest coating the wires with electrical grease. The buss bars are commonly aluminum which oxidizes causing issues. de-oxidation compound lessen this.
