โMar-23-2018 05:54 AM
โApr-09-2018 03:08 AM
โApr-08-2018 08:44 PM
โApr-08-2018 05:01 PM
โApr-08-2018 02:38 PM
Only True Mosnowman wrote:
I just ordered Motorcraft DEF off of Amazon. My 2018 Ford F350 manual specifies I use Motorcraft brand. This is my first diesel, so like many other newbies I am apprehensive, most likely for no good reason. Is Motorcraft a good brand? Thoughts?
โApr-08-2018 08:25 AM
โApr-08-2018 05:23 AM
โApr-06-2018 11:09 AM
โApr-05-2018 06:28 PM
jplante4 wrote:
DEF is different from DPF. With the particulate filters (2008 thru about 2010), they increased the exhaust gas recirc and filtered out whatever didn't get re-burned.
DEF uses a catalytic filter and the DEF fluid to wash the particulates out. The EGR rate was reduced.
People who know and people who have owned coaches with both technologies say that DEF is a great improvement. At any rate, if you look at a graph of gas vs. DP class As, the turning point was when the government got involved.
โApr-05-2018 05:01 PM
โApr-05-2018 04:45 PM
โMar-26-2018 10:38 AM
โMar-26-2018 09:53 AM
SDM wrote:
Have a 2011 Duramax. Have had a sensor problem. Dealer says the def from Walmart is giving some problems. Any thoughts.
โMar-26-2018 09:05 AM
Wild Card wrote:
They make a DEF refractometer. You can buy one at most auto stores. Take your own sample then you'll know.
โMar-26-2018 08:58 AM
Rancher Will wrote:
I own a small trucking company, two cattle ranches and I pull our Montana 5thWheel with a diesel RAM truck. On average I pay for over 150 gallons of DEF per week. I learned that I save over $2.00 per 2-1/2 gallon jug by my employees buying at WalMart rather than at truck stops and other sources. We have had no problem with WalMart DEF in the Blue jugs plus it is cheaper than even bulk supply.
