Sep-13-2017 11:11 AM
Sep-18-2017 01:20 PM
Sep-18-2017 09:12 AM
Sep-17-2017 04:40 PM
Sep-16-2017 07:30 PM
Sep-16-2017 08:48 AM
Sep-16-2017 07:47 AM
Sep-14-2017 09:37 AM
Sep-14-2017 07:50 AM
Sep-14-2017 05:35 AM
jdb7566 wrote:darsben1 wrote:
I have a small area of delamination just below the RV refrigerator outside access panel.
If I remove the panel completely I would have room to put something in there to reglue the area. spraying would be easiest for me but I want effective. The area extends downward abut 30 inches and side to side about 24 inches.
I am looking for a relatively simple fix that I can do myself.
What are your thoughts?
I am looking for first/second hand experiences. I know how to search and look at YouTube videos on my own.
There are no simple fixes when it comes to delamination. It's like a cancer that needs to be cut out. A new rig may be in order. I'm sure CW have many fine units for you to peruse.
Sep-14-2017 05:25 AM
Sep-14-2017 05:08 AM
Sep-13-2017 08:06 PM
KMLsquared wrote:
Don't mean to hyjack but what if the leak was cured. Is there any harm in not fixing the delam issue?
Sep-13-2017 08:04 PM
Kayteg1 wrote:darsben1 wrote:
Keyteg1
How long ago did you do this? I am thinking about the longevity of the repair
I did the first repair about 3 years ago and more last spring.
Bare in mind none of those glues are water-resistant so they will hold as long as there is no water penetration.
On some areas like cord boxes, I used epoxy to laminate the old wood, what adds strength and makes it waterproof, but epoxy has its limits in application and doesn't work too well on vertical surfaces.
If you don't open the bubble and dry it, per my experience the trapped moisture will sit there for a year if no longer - still dry-rotting the wood.
Sep-13-2017 07:14 PM
darsben1 wrote:
Keyteg1
