โAug-21-2017 01:55 PM
โAug-22-2017 06:28 AM
fourthclassC wrote:
Howdy, Just a suggestion here when I have had electric brakes sticking. With the drum off inspect the ability of the magnet to move freely on its mount. Not sure of the correct term here, but the magnet needs to slide freely off and on against the inside surface of the drum.
โAug-22-2017 06:18 AM
โAug-22-2017 12:23 AM
โAug-21-2017 05:26 PM
โAug-21-2017 05:18 PM
time2roll wrote:
If you have a clamp-on DC ammeter you can check each wheel is getting about 3 amps.
Too low is a bad connection, too high is a short.
Since all four seem consistent at least pull one off and inspect.
Is it too early in the thread to suggest a disk conversion?
โAug-21-2017 03:04 PM
โAug-21-2017 02:30 PM
โAug-21-2017 02:16 PM
donn0128 wrote:
Electric brakes do not have the travel that hydraulics do. Adjust to tight and back off no more than 4 clicks. Any more and you simply do not have sufficient travel.
โAug-21-2017 02:11 PM
โAug-21-2017 01:58 PM
