Extend a Stay, Which Hose?
TimLoon
I have the extend a stay with one fitting. I use it to feed my grill and portable stove. I would like to back feed the RV from a 20 lb. portable tank when necessary. Easy to do if you have a 2 port setup but I only have the 1 port. I can't find a hose that fits this application. Anyone have a lead on that info? Appreciate all input. Tim
2004 Tiffin Allegro 32BA
2005 Honda CRV Toad
Pretty wife of 34 years as copilot
6 REPLIES 6
wa8yxm
Look for Propane Refill Adapters. I had a post with a link but the software is not being nice today and won't let me post it.
jpmihalk
There is also this which will give you both a grill adapter and a tee to hook up an external tank and comes with the hoses to do so.
https://www.amazon.com/Camco-59123-Propane-Brass-Port/dp/B0014JG7RQ/
John & Kerri
2016 Thor Hurricane 35C with our pups MacDuff, Piper and Annabelle
red31
sorry, meant steak saver but it won't work, a bottle refiller will
https://www.amazon.com/Mr-Heater-Propane-Refill-Adapter/dp/B000AMC5WO
pol to 20lber, threaded connector to hose.
Dutch_12078
What you have is an "Extend-A-Flow" fitting, not an "Extend-A Stay" fitting. The port that's used to feed your grill will not accept the hose needed to connect an external DOT cylinder. You need the two port "Extend-A Stay" version and the POL hose that comes with it.
Dutch
2001 GBM Landau 34' Class A
Sprink-Fitter
red31 wrote:
"teak saver" - google
I searched "teak saver" lots of stuff made from teak for the bathroom.
2006 Coachman Adrenaline 228FB
2012 Can Am Commander XT 1000
red31
