โJun-22-2019 06:10 PM
โJun-25-2019 11:59 AM
โJun-24-2019 07:33 AM
SoundGuy wrote:time2roll wrote:
Seems like the biggest complaint is longevity and overheating. I recommend connecting with oversize 12v cable to minimize voltage drop. Too bad these portable macerators are not 120vac powered.
Bought my FloJet in 2006 so I could avoid dump station lineups, used it constantly since then, no issues at all, 'though I did finally buy a rebuild kit a couple of years ago because one of the rubber impeller vanes had broken off. 12 vdc is the only way to go as it means the ability to use the pump anywhere at any time, no need for a 120 vac power source. I'd also never buy any macerator that depends on a water source for operation - no need, the FloJet macerator is reliable, does what it's supposed to do, and will work just fine for years. Criticism always seems to come from those who've not owned one or have never used one. :S
โJun-24-2019 05:10 AM
โJun-23-2019 03:17 PM
โJun-23-2019 01:44 PM
Lynnmor wrote:
Dealing with a huge tub full of 1/2โ 50โ hose, 3/4โ 75โ hose, wiring, and switch, then connecting them is a PITA. Then draining the two hoses, coiling them and stuffing them in the tub is a PITA. Finally draining the pump and allowing it to dry before is another inconvenience.
โJun-23-2019 10:29 AM
SoundGuy wrote:I am not the only one.
โJun-23-2019 09:52 AM
SoundGuy wrote:IAMICHABOD wrote:
is a major PITA to use and setup and makes a lot of noise.Lynnmor wrote:
That is correct, but if you NEED one, then you do need it.
Don't understand the "PITA" part :h, using a FloJet is certainly a cleaner and easier method of off loading black water than fooling with a stinky slinky and way too expensive, too heavy wheeled tote tank. ๐
โJun-23-2019 08:12 AM
โJun-23-2019 07:58 AM
โJun-23-2019 07:30 AM
โJun-23-2019 07:11 AM
โJun-23-2019 07:05 AM
โJun-23-2019 06:32 AM
โJun-23-2019 05:16 AM
