Oct-04-2017 09:56 PM
Oct-05-2017 02:08 PM
pnichols wrote:Or it's really cold and they want the coach at 70F.SidecarFlip wrote:Excellent point that seems to be "lost" on many that complain about their propane furnace sucking up so much battery current. I suspect that they may have a weak, or too small, RV battery bank problem instead.
Keep in m mind that the furnace blower only runs intermittently. Not continuously.
Oct-05-2017 11:23 AM
Oct-05-2017 10:14 AM
Oct-05-2017 09:34 AM
SoundGuy wrote:old guy wrote:
you will benefit with more power with the 6's then with one or even with using two 12's. the 6's will last longer
A generalized statement that simply isn't true - a pair of G31 12 volt deep cycle batteries wired in parallel offer approximately the same AH capacity as a pair of GC-2 6 volt deep cycle batteries wired in series. For those running heavy loads with an inverter a pair of 12 volts can actually be preferable as they're more likely to suffer less voltage drop under heavy inverter load than will a pair of 6 volts. The devil is in the details. 😉
Oct-05-2017 07:56 AM
Oct-05-2017 07:45 AM
Braces wrote:
2014 Montana High Country Thinking of changing to two 6volt batteries. Don't have access to my trailer right now and need to know how much power the fan uses to see if running furnace at night when cannot run the generator would be practical. No genny 8 to 8 in national park. I realize there are a lot of variables so if you know the approx power draw of the fan motor maybe I could have a reasonable idea of the amp/hrs needed to keep reasonably warm.
Oct-05-2017 06:35 AM
Oct-05-2017 06:30 AM
Oct-05-2017 06:29 AM
Oct-05-2017 05:32 AM
Oct-05-2017 12:28 AM
Oct-04-2017 10:18 PM
Oct-04-2017 10:12 PM
Oct-04-2017 10:00 PM
