โJun-26-2017 05:57 AM
โJul-10-2017 05:14 PM
โJul-10-2017 04:45 PM
โJul-10-2017 04:30 PM
โJul-10-2017 04:23 PM
โJun-29-2017 08:43 AM
โJun-27-2017 11:20 AM
BadgerMcAdams wrote:Actually the more pressure you put on the seal, up to a point of course, the better the seal will work. If the grease won't compress it will expand the very soft rubber plug like it's designed to do. That is the point of least resistance. Check out the schematic.
The problem is that once all the space is filled with grease, any time you add an additional squirt or two, it has to go someplace. Now if grease is like water, it doesn't compress (or at least doesn't compress much). The weak spot on the whole thing is the seal at the back. The grease will squeeze through where the seal touches the spindle. Or, it will just use hydraulic action and push the seal out.
To steal the words of a great Engineer, Mr. Scott, "Ya canna break the laws of Physics!"
โJun-27-2017 11:16 AM
Lynnmor wrote:But the poster said "Leaking seals are a known Lippert issue." I was merely pointing out that the discussion was centered around the hubs from a different company. Because Lippert has an issue doesn't necessarily mean that Dexter has an issue also.fj12ryder wrote:
We're talking about Dexter, not Lippert.
They are all the same, for example, if it is a #84 spindle the seals and bearings are the same. Perhaps one brand might have had a bad run but the discussion can include any brand of the same type.
โJun-27-2017 10:27 AM
โJun-27-2017 09:19 AM
โJun-26-2017 09:48 AM
โJun-26-2017 08:57 AM
โJun-26-2017 08:15 AM
โJun-26-2017 08:11 AM
โJun-26-2017 08:04 AM
