Thx WestEnd, and great fyi for this non-mechanic about the intake/outtakes! So if that is the case and I were (not doing anything till I know what the heck I'm doing 1st!) to use the leaf blower inside by sticking down the vents, if any debris etc were in the duct lines where would it exit? Or rather, would it not and just be pushed up against the heating chamber, etc. (wherever the ducts go from the floor down?)
Again, bought used and the Seller lived in the Jersey Pinelands and the RV sat in his forest of a backyard when not in use (which was largely the case). So I can only imagine......rodent motel!!! Mute point really where or how the rodent problem (if the case but certainly leaning that way....) started. But I like your idea, dropping my Underbelly and a full inspection!!! In a perfect world, I would have done that at the buy, but who knows if the Seller would even have agreed, taking to a shop, etc.... The odor certainly is not getting worse, and actually/maybe might be subsiding some. And if it is mouse urine, the heat I would imagine has to ultimately "heat out" and dry it all up eventually right? But if nest, then of course they keep peeing all over the bloody place too!!!
I want to kill them with poison, but not a good idea because more then likely they will drop dead in the nest or in a duct line, behind my floor kitchen cabs (which have all the tell tale poop signs). So I have layed out Bounce dryer sheets in just about every cab as deterrents or repellents. Key is to get them OUT and then start safeguarding with Bounce sheets, moth balls, Peppermint Oil, and Steel Wool stuffed in every bloody hole that is bigger then 1/2" throughout the entire coach!
This is another venue/forum entirely, but for a luxury Heartland Bighorn 5th, disgrace on all the shortcuts or laziness they did in the build. i.e. leaving wide, like open walls folks!, openings behind the cabinetry on the kitchen floors! Sure, you will see the "Great Stuff" product blown around the wiring but half ass. Some holes ignored completely. Q: Mice have been around for a billion years and the RV industry knows the damage they do. And mice can easily eat away and thru the great stuff. But steel wool, NOOOOOO, NEVER, IMPOSSIBLE. So putting aside the B.S. money costs, why would they not use steel wool around the hole lines and fill in with the great stuff??? Again, another forum and sorry to ramble on, I'm just frustrated.
Thanks again for any help and keep replying!
"Life is short my friends, and if you don't stop to take a look at it every once in awhile, your gonna miss it!" --- Ferris Bueller ---
