โJun-18-2016 06:28 AM
โJun-19-2016 02:12 PM
TomG2 wrote:
I believe in scales and measurements instead of guesses.
โJun-19-2016 07:39 AM
โJun-19-2016 06:40 AM
TomG2 wrote:BarneyS wrote:
..snip......The OP has 6 links under tension which is just about perfect. ....snip.....Barney
I have owned many GM and Ford pickups. "None" referenced the number of links under tension or hanging in their setup instructions. They specify scales and body measurements. Snip...
โJun-18-2016 03:16 PM
โJun-18-2016 02:03 PM
โJun-18-2016 01:43 PM
bandit86 wrote:
Is the second or third picture right?
โJun-18-2016 01:25 PM
myredracer wrote:
Nice vintage Reese dual cam hitch! Spring bars come in different ratings and the required rating depends on actual tongue weight. Maybe someone knows ratings on the older DC WDHs. If bars are too "light", it may not be possible to transfer enough weight but it's hard to tell by the info. so far. When the TH is fully loaded, it could be that the bars and hitch won't have high enough rating. I'd guess you'd need 1200 lb bars. If you do need more tension on the bars, it looks like the hitch head is already tilted as far as it can go tho. Going to a scale would be a very good idea to get weights and would be good to know with and without any toys in it.
The "crook" in one bar end isn't centered on the cam. It's important to have them centered when in a straight line and truck and trailer are fully loaded for a trip. Can be harder for a TH with the amount of tongue weight variation.
A bit of squat in the rear of a truck is normal and okay, usually around 1 -2". It might be that the 2 3/4" will reduce when the WDH is fully adjusted and ready to go. But then, the rear is 3" or more lower to start with and not sure if handling could be adversely affected? As long as you aren't exceeding payload or RAWR, squat is fine. Some don't like the squat and install air bags. The thing that is really important is that once you have the WDH hooked up and properly adjusted, the trailer needs to sit level to slightly nose down. I had to get a ball with 1" rise to get our Reese DC to work out.
โJun-18-2016 11:35 AM
โJun-18-2016 10:31 AM
โJun-18-2016 10:16 AM
bandit86 wrote:
Should all start measuring inches of chains
โJun-18-2016 09:12 AM
TomG2 wrote:
Measurements will get you to a starting point. Scales are the best and only weigh to know what you have got. Saying things like "three links" or "five links" only adds to the confusion. What if your chain has thirty links and mine only ten? How can you relate to that?
โJun-18-2016 09:03 AM
โJun-18-2016 08:15 AM
bandit86 wrote:
Thanks for the links, I was misinformed about the purpose of the hitch. I'm not so worried now
โJun-18-2016 08:13 AM
