Yeah, you didn't tell us how much battery capacity you have.
But I'm so far very happy with 400w handling 230ah of battery.
I'm not sure there is overkill as far as panel size. Unless you consider spending a nickel more than necessary as overkill.
Consider this...the best way to charge your battery is to not discharge it to begin with. So with a lot of panel capacity, you can choose to run things like the water pump (showers or dishwashing) or watch TV, while the sun is high. Use that excess panel output instead of battery supply.
We did the same thing with our generator. Try to do water pump things while it was running, and at the time we had to run it to watch TV anyway. We have carried those habits over to our solar life.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
