โJun-09-2018 06:04 PM
โJun-11-2018 03:05 PM
โJun-11-2018 11:26 AM
โJun-11-2018 09:19 AM
โJun-11-2018 03:46 AM
โJun-10-2018 02:16 PM
โJun-10-2018 08:24 AM
โJun-10-2018 08:22 AM
โJun-10-2018 07:27 AM
Lynnmor wrote:
After watching how my electric awning flipping around like a fish out of water, I no longer use the useless thing. If it can't protect an area when the weather is less than perfect, what is the purpose in having it?
โJun-10-2018 07:09 AM
โJun-10-2018 06:58 AM
SoundGuy wrote:ReneeG wrote:
Carefree is the most popular brand. Check for local RV techs or dealers with good reputations to do it for you.
Our previous K-Z Spree came stock with a Carefree of Colorado power awning and it was such a POS I couldn't wait to get rid of it. My dealer agreed to swap it out for a Dometic 8500 manual awning, asking only that I wait until the fall when his shop wasn't so busy to have the job done. That gave me 6 months with the Carefree and it proved to be the worst awning I'd ever had. It had little tilt but when it collected a sufficient quantity of water it would suddenly dump off one end, soaking anyone who happened to be unfortunate enough to be anywhere nearby. The swap work fine but holes in the trailer side wall after the Carefree was removed had to be sealed and although I had no later issues with leakage I did have quite a few plastic caps where these holes were located. Unquestionably the swap was worth the effort as I could lower the Dometic at a much more severe angle and therefore could leave it deployed in even the worst rainstorms. All that said, our current Coachmen came with a Dometic 9100 power anwing that also does tilt quite a bit so I can leave it deployed as well during heavy rainstorms, no issues at all. I'd only retract it when the wind really comes up, no different than I'd do with the manual awning. JMO, but if the OP wants a power awning I'd recommend the Dometic 9100.
โJun-10-2018 02:37 AM
โJun-10-2018 01:29 AM
โJun-09-2018 11:46 PM
path1 wrote:
My old manual so much better in many ways
โJun-09-2018 09:56 PM
