โJun-21-2021 01:26 PM
โJun-24-2021 05:44 PM
โJun-22-2021 08:42 AM
โJun-22-2021 04:46 AM
โJun-21-2021 11:31 PM
โJun-21-2021 08:11 PM
โJun-21-2021 07:37 PM
โJun-21-2021 07:15 PM
Horsedoc wrote:Separate electric motor drives the A/C. In many EVs the cooling system also serves as a heat pump when needed. The A/C with a separate motor is more efficient as the compressor can be driven at the correct speed instead of up and down at the engine speed. The cooling system in most EVs also cools the battery when needed. The cooling system works quite well using about 5% of the range in hot conditions. EV can be pre-cooled or pre-heated before you drive using utility power if connected. Even inside your closed garage.
I have driven the Toyota Prius when they first came on the market years ago. I liked it and it ran fine with no problems, even in the summer.
If, there is nothing (NO engine) but an electric motor to make these new electric cars go, what powers the A/C and on these days here in the South with 90 percent humidity and 90 degrees?
I guess I am just old school and don't understand how this kind of setup could be of value for anything other than driving to the market and back.
โJun-21-2021 06:53 PM
jdc1 wrote:
News on the EV front! Long Beach California charges its city buses by....picking up passengers. Wireless technology has improved so much, charging is as simple as pulling up and..that's it. Just like a smart phone (not mine) or watch, you can charge effortlessly. The charging system is embedded in the road. This will become more widespread soon....mostly in metropolitan ares, of course.
โJun-21-2021 05:57 PM
โJun-21-2021 02:35 PM
โJun-21-2021 02:26 PM
โJun-21-2021 01:58 PM
wanderingaimlessly wrote:
The same battery that motorvates you from point A to point B, but in the summer, they better be closer together, with fewer traffic standstills.
โJun-21-2021 01:45 PM
โJun-21-2021 01:28 PM
