Locked out of RV
Son_of_Norway
This concerns the door latch below the deadbolt. I have the key. I have no problem locking and unlocking the latch, but I can't open the door with the outer latch. I pull on the latch and it won't open the door. The door isn't jammed, it acts like the latch is still locked.
So, I am locked out of my RV. All the windows and other ways to get in are closed and locked. There are no compartments or other ways to get in. I don't mind ruining the latch to get in, it needs to be replaced anyway. I have drills and other tools. I don't want to break a window.
What can I do?
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
30 REPLIES 30
DancinCampers
Try prying the latch handle up and then try opening.
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2020 Chevy Equinox, Blue Ox Aventa II, Air Force One
If You Obey All The Rules, You Miss All The Fun
billyboy
I adjusted the door jam plate so the latch doesn't hit as hard when the door is closed, worked for me after replacing the lock once
09 winny adventurer 32h 33 ft towing 015 focus
Dusty_R
The latch/lock on our mh broke while it was still under warranty, got it replaced. Then the replacement broke. I went to a local small RV parts place and got a new one but different make. No more problems.
3_tons
I got locked out of mine once and what worked was that I hit the dang lock hard once or twice with a rubber mallet and at that point the lock decided to work fine again - lol
3 tons
Son_of_Norway
Thank you all for the suggestions. I will report back on what worked out for me.
Miles and Darcey
Denver, CO
pianotuna
Nomad III
Nomad III
Hi,
I'm on my second lock. I try to shut the door gently and have the latch open as I do so.
It is the choice of metal they used--it is extremely annoying.
Fortunately I'm in a class C, so I do have alternate ways to enter.
Regards, Don
ktmrfs
I recall this being a problem on on brand of locks, and there was a recall on the locks. Just before the recall, I had mine fail, luckily it was on a cargo trailer with a drop down rear door.
2011 Keystone Outback 295RE
Terryallan
Mine does that sometimes. when it does, it is because the door is not completely shut. I have to push it shut, and the latch clicks, and then I can open it.
Just a thought. Something to try.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
LadyRVer
I had Emergency Road Service when that happened to me. They sent locksmith.
Or just call locksmith.
2oldman
WD40, and plenty of it.
ferndaleflyer
Good Sam or Coach Net would take care of it OR call a lock smith
jdc1
You can also drill out the cylinder yourself and save time and money. Then you'll need to replace the lockset.
swphotobug
We ended up breaking the window and cutting the screen. Both easy enough to replace. We now leave a window that we can climb through to get in.
jdc1
The cam in the lockset gets worn out. They are made of pot-metal. If you can pry the jamb just enough (1/8") you might get it open and save yourself time and aggravation.
Lwiddis
X2, locksmith.
