LP Issues
keywestrebel
The problem started with our electric/lp water heater. We are on shore power and switched to electric on the hot water heater months ago with no problem. Recently the water wasn't getting as hot, only warm. Before we could look into that, I switched on the gas to heat the water. It would not light, only made several attempts to. Since the time the LP wouldn't light, my oven/stove won't light and now my Dometic fridge is out too, even though we have shore power.
Any suggestions?
Thanks
Frank
5 REPLIES 5
Almot
No gas - maybe. Still doesn't explain why the heater doesn't work well on shore power, "warm but not hot".
j-d
Fridge and Water Heater both need 12VDC (from House Battery or Converter/Charger) to operate. Do you have good "12=Volt" (usually 13.8 volts) to the those appliances? This wouldn't help with most stoves.
1492
Moderator
Moderator
Moved from Forum Technical Support
donn0128
Your new to this I assume?
This was posted in the wrong place. So I have notified the moderator to move it for you.
Now to your problem,,,,, your out of gas.
BTPO1
Sounds like you might be out of gas.
The LP gas leak/detector may have been shut off accidentally.
The Dometic refrigerator might be set on gas and not electric or auto.
JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
