Sep-07-2019 11:20 AM
Sep-08-2019 09:23 AM
Sep-08-2019 08:17 AM
CA Traveler wrote:pianotuna wrote:So you plug in shore power to the female outlet and the male end of the permanent extension cord is now hot? There must be more to the story.
Hi,
I have a permanent extension cord #10 with a male end at the front of my RV and a female at the rear. I simply plug the Shore power cord into the female outlet. That lets me power the RV from either end safely.
Sep-08-2019 07:00 AM
ScottG wrote:Old-Biscuit wrote:
With DUAL 50A Receptacles Front & Rear and detachable 50A Power Cord I have NOT needed an extension cord
How do you switch between them?
Sep-07-2019 11:35 PM
ScottG wrote:Old-Biscuit wrote:cougar28 wrote:ScottG wrote:Old-Biscuit wrote:
He saying he has a receptacle that common between the two on his. One in front and one at the rear so he just uses the closest one to the power pedestal to plug his cord into.
The 2 AC Source Inputs went to an Auto Transfer Switch \
The ATS were troublesome (Parallax)....both failed and Parallax knew of problems. Wanted to keep sending me replacements.... :S
I threw the junk away and installed a 125V subpanel wired up the 2 AC Source Inputs to 50A CBs that are mechanically interlocked so only one AC source can be On at a time.
Need a part........50A CBs available at any hardware store. No more troublesome relays/contacts etc.
Just a simple manual transfer by flipping the CBs
I knew it would be above-board! :B
Sep-07-2019 09:53 PM
Sep-07-2019 09:46 PM
Hi,
Sep-07-2019 09:31 PM
Sep-07-2019 08:51 PM
Sep-07-2019 07:52 PM
ScottG wrote:
Thx, I knew what he was saying. Problem is, if you're plugged into one and there's no switch to select between them, the other will be hot and present an electrocution danger.
That's why I asked.
Scott
Sep-07-2019 06:39 PM
Sep-07-2019 04:33 PM
Boomerweps wrote:
Last camp, the power pedestal for my site was too far away for my 30' mains cable.
I needed between 15-20' to reach.
Sep-07-2019 04:13 PM
Boomerweps wrote:
75'! 125'! Great Googly Moogly!
MASSIVE voltage drop!
Yes, it was a private CG.
Sep-07-2019 03:51 PM
Sep-07-2019 03:21 PM
