โOct-04-2014 05:03 PM
โOct-05-2014 03:07 PM
โOct-05-2014 02:40 PM
jplante4 wrote:
I've rebuilt more than a few Rottenchester Quadrajunk carbs in my life and $400 is cheap, believe me.
โOct-05-2014 10:45 AM
โOct-05-2014 07:09 AM
โOct-05-2014 05:38 AM
โOct-05-2014 04:48 AM
โOct-05-2014 02:55 AM
โOct-04-2014 07:53 PM
darsben wrote:westend wrote:
If Gary owns a 454 and seems to love it, you'll be fine. He will have a work ethic above what you can get elsewhere.
I don't know if Californians are unaware of the nuances of smog tests, the testing must be similar to other areas of the country. We had mandatory annual testing in MN until the populace got disgusted with the scam and it was abolished. During that time, myself, and every other backyard mechanic, discovered how to make even the worst oil-burning V-8 pass emissions testing. Here's the recipe: Change oil and filter, run gas tank down to 1/8 of a tank. Add a quart or two of isopropyl alcohol into the tank. Drive to the testing center. I have seen vehicles that were unable to pass emissions testing even after a full tuneup, pass with 0.0 on the test readouts after the alcohol addition.
90% isopropyl not the 50% that is common
โOct-04-2014 07:48 PM
โOct-04-2014 06:29 PM
โOct-04-2014 06:10 PM
โOct-04-2014 05:45 PM
