New "friction hinge" exterior door
Dayle1
Our new toyhauler has these new "friction hinge" exterior doors. The door for the forward living area works alright. It operates with reasonable force and stays at any position. But the second door into the garage area is way too stiff. I can open or close it, but it takes a lot of effort and I can feel and hear the stress on the door, hinges and door frame. Something will fail eventually. So I'm wondering if there is some way to adjust the stiffness of these "friction hinges"? Anyone have some experience with this issue?
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
2 REPLIES 2
Wild_Card
I opened up the hinge a little with a screwdriver and lubed himge and gasket.
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
ScottG
Subsribing.
We have a TT on order that has these things. I don't like them at all and would subvert them if possible.
