โFeb-05-2020 06:17 AM
โFeb-06-2020 08:56 AM
enblethen wrote:
It is normal to have metal pipe grounded to stop any potential (or at least reduce the chance) arcing.
It could be a higher resistance then a good solid ground connection via a copper wire.
โFeb-06-2020 08:40 AM
Bud
USAF Retired
Pace Arrow
โFeb-06-2020 08:30 AM
opnspaces wrote:kmb1966 wrote:
I have been working on my Norcold 1200 again and have noticed that the unit will power up and operate when only connecting the 12 volt (+) supply to the rear control board connector labeled "12V". The connector labeled GND can be disconnected totally. Obviously there refrigerator is somehow already grounded somewhere, but I am wondering if this is a problem or is normal??
I think you all missed the question "Is this a problem or is it normal?".
No it is not normal which you can gather from all the responses trying to help you figure out how it's possible. But is it a problem? Probably not but I guess that's where you have to define your meaning of the word problem. Should the actual ground be fixed or attached? Absolutely.
โFeb-06-2020 06:48 AM
โFeb-06-2020 03:53 AM
โFeb-05-2020 07:02 PM
โFeb-05-2020 12:26 PM
โFeb-05-2020 10:54 AM
โFeb-05-2020 09:23 AM
vermilye wrote:
Do you have copper propane piping? One of my refrigerators ran on the hot & the propane copper pipe until the broken ground was discovered.
โFeb-05-2020 08:21 AM
^^^^^^^ This ^^^^^^^
โFeb-05-2020 07:50 AM
โFeb-05-2020 07:49 AM
โFeb-05-2020 07:09 AM
Bud
USAF Retired
Pace Arrow
