Oct-22-2019 12:13 PM
Oct-22-2019 06:17 PM
Oct-22-2019 04:08 PM
Oct-22-2019 03:54 PM
wa8yxm wrote:
Now due to a very attractive sale at Camping world I just "installed" a Surge Guard by TRC (The company name on the box is different but it's TRC)
Oct-22-2019 03:52 PM
time2roll wrote:That do make a difference for sure. For cords that have to be plugged in at both ends, not so much.fj12ryder wrote:So my cord pulls nicely from the mouse hole. EMS not going to fit. Need a place to store in transit and need to pull it out etc.
I'm not really sure I understand this "One more thing to remember to do". My portable EMS is always plugged into my electric cord, and the EMS is what is plugged into the pedestal. Last time I checked you had to plug into the pedestal to get power to the RV.
Oct-22-2019 03:04 PM
Oct-22-2019 02:50 PM
Oct-22-2019 02:40 PM
Oct-22-2019 02:26 PM
Oct-22-2019 02:21 PM
Oct-22-2019 02:01 PM
MDKMDK wrote:The problems are rarely apparent when you plug in and almost always occur UNDER LOAD. Especially true on 30A pedestals.CA Traveler wrote:
My 2004 hardwired unit is in the second rig. In each case it's installed without cutting/splicing any existing wiring so trivia to remove and restore original wiring. It also has a remote display inside the rig which is a HUGE advantage over a portable. Voltage, amps, error codes are all easy to see. A data wire has to be routed to the remote.
Ya gotta plug it in, don't you? You can easily see the portable unit's display as well, when you're outside the coach doing that. If it reacts to something and cuts power, you're not likely going to be able to either trouble shoot or resolve it from the comfort of the inside of your coach, you're most likely going to have to exit the vehicle at some point to resolve the problem, so it's really not a huge advantage. Very few shore power issues occur inside your coach.
Oct-22-2019 02:00 PM
Oct-22-2019 01:55 PM
Oct-22-2019 01:42 PM
Oct-22-2019 01:26 PM
Oct-22-2019 01:25 PM
